cat f-35 creeps then stops
HELLO TO ALL,
I HAVE A CAT F-35 ELECTRIC FORKLIFT. I KNOW I POSTED THIS UNDER F-30 BUT THERE WAS NO CHOICE FOR THE F-35. SO HERE GOES MY ISSUE. WHEN YOU PRESS THE THROTTLE PEDAL IT SOMETIMES BARLEY CREEPS ALONG FOR A SECOND THEN STOPS ALL TOGETHER. VERY RARLEY WHEN PEDAL IS FULLY PRESSED IT WILL SHOOT OFF FULL SPEED BUT ONLY FOR A SECOND. I RECIEVED THIS LIFT WITH THIS ISSUE. I WAS ALSO INFORMED THAT A TECH HAD SAID THE ACCELERATOR CONTROL WAS BAD. I REMOVED IT. PULLED IT APART AND INSPECTED. NOTHING OUT OF ORDINARY. SO I CLEANED IT OF WHAT LITTLE OILY RESIDUE AND DIRT THAT WAS ON IT AND PUT IT BACK TOGETHER AND STILL HAVE SAME ISSUE. IM HOPING SOMEONE HAS AN IDEA OF WHATS WRONG, HOW DO I TEST THE ACCELERATOR CONTROL? ANY AND ALL HELP IS GREATLY APPRECIATED, JASON
MODEL - F 35
SERIAL#- 5FB1819
  • Posted 6 Apr 2016 04:26
  • By kettle1
  • joined 6 Apr'16 - 4 messages
sounds to me like the directional contactors are worn out, dirty tips maybe
put tip kit in them or replace contactors
but by all means DO run the accelerator test in onboard diagnostics to verify that all the steps in the accelerator are working correctly.
pull the drive fuse
turn on key
put run/diag switch on card into diag mode
it will show d on display
then cycle switch to run test, each test you have to do in order it looks for so u need diagnostic sheet to tell you which one is which when it asks.
there should be a schematic under hood showing you panel diagram and will also have diagnostic routine on this, if it's gone then you need to get the manual.
as you run each test it will advance to next test if it passes.
keep cycling till it get to accelerator test and if it pass then accelerator is ok.
i'll look and see if i have this diagram and may can send it to you to help you if you need it now.
put your email in your profile in signature and enable 'show signature' when you post to thread.
  • Posted 25 Apr 2016 05:55
  • Modified 25 Apr 2016 06:01 by poster
Thank you for the tip, ill try that..
I really appreciate all of your guys' help.
  • Posted 15 Apr 2016 21:57
  • By kettle1
Google Cat F35 manual and you should see some for sale on Ebay. The only other way is contact your local Cat dealer and see if they have one that they would be willing to make a copy for you.
  • Posted 15 Apr 2016 10:11
  • By Partsguy5
Thanks for help. I do wish I could locate a service manual but have had no luck. I have replaced the accel control box with a supposed working unit. It didn't change anything. Here's what I did find. There is a set of dual contactors connected to capacitor. It does not always engage. But when it does truck takes off and seems to operate properly with the accelerator pedal pressed either partially of fully. Then it seems like it dies out after a few seconds. Have no idea hat should activate that set of contactors. Thanks again for any and all help
  • Posted 15 Apr 2016 09:36
  • By kettle1
there is no need to type in caps, that is usually consider "shouting".
In this truck, it is possible to use the "on-board diagnostics" to be able to check the 'steps" in the accelerator control to check to see it is working correctly.
my quick wag is that your accelerator control box has lost a c-clip on the part that moves inside to block the operation of the photoelectric sensors.
you should get new or known good accel control box to check or get the manual and use the onboard diagnostics.
  • Posted 15 Apr 2016 08:33
  • Modified 15 Apr 2016 08:34 by poster
NOBODY HUH! ANY OF THE EXPERTS HAVE ANYTHING AT ALL, ANY SUGGESTIONS???
  • Posted 15 Apr 2016 01:20
  • By kettle1
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Terberg YT220
VETTER Forks, Inc.
