CAT Error Code - Alarm 57 mod 01
Anyone know what i can tell my Tech on how he should proceed?
  • Posted 23 Aug 2019 08:00
  • Discussion started by Bond
James B.
Thanks, will try and let you know.
  • Posted 24 Aug 2019 00:57
  • Reply by Bond
James B.
Models:
NR3000, NR4000, NR4000P, NR4500, NR4500P, ND2500, ND3000, ND3000P
Problem:
Code 57 Mod 1 is a code that is set when there is an open in one or more of the hydraulic control valve circuits.
Cause / Discussion:
Mast cables to the hydraulic control valves are vulnerable to wear and breakage.
Solution:
When this code appears, use the Handset or PC Console to turn off the Open Valve Diagnostics
option in the Sicos. The code will no longer appear. Try each function. The function that has an open
circuit will not work. This will allow for quicker trouble shooting, because you will know what circuit is open.
  • Posted 23 Aug 2019 16:07
  • Modified 23 Aug 2019 16:08 by poster
  • Reply by swoop223
If 36v, check pump inverter connections
  • Posted 23 Aug 2019 11:41
  • Reply by prepaito_d
  • iztapalapa, Mexico
Whatsapp +525513637801
Is it 36v or 24v?
  • Posted 23 Aug 2019 11:34
Model - NR4000
Serial # 5NR3701700
  • Posted 23 Aug 2019 10:28
  • Reply by Bond
James B.
Model and serial?
  • Posted 23 Aug 2019 10:22
Ottumwa, IA, United States
Wentzville, MO, United States
Harrisburg, SD, United States
