CAT/EP20KT Display "Lo"
Hello ,
Our Forklift CAT/EP20KT showing "Lo"in the display , I had replaced the logic card , Contactor tip set s, and tried with other battery , Please advice ??
  • Posted 28 Apr 2013 14:18
  • By lishoy_t
  • joined 29 Oct'12 - 70 messages
  • dubai, United Arab Emirates
lishoythomas619@gmail.com
The display shows "LO" LO
This error may be due to the following causes:
· Poor connection between the battery positive and contactor B + line (check for any paper, rubbish, dust etc in the line contactor contacts -> AIR BLOWING THE LINE CONTACTOR CONTACTS)
· Connections "X" or "Y" line contactor loose
· The online contacts do not close properly (crap in contacts)
· Incorrect connection of thin wires (color black) that runs from the positive battery positive B + to B + control panel
· ESD Cable (cable discharge any static) loose. This cable is in the steering column, in the micro ignition key and close the top cover from the top of the address
· Faulty logic card
· Switch DRS (diadnóstico / run / setup) defective
· Cable DC / DC converter loose
  • Posted 28 Apr 2013 19:00
  • Modified 28 Apr 2013 19:32 by poster
  • By marcos_g
  • joined 30 Jun'11 - 76 messages
  • CANTABRIA, Spain
Hi friend, i send you information in your mail.
  • By marcos_g
  • CANTABRIA, Spain
Terberg RT223
Terberg YT223
