CAT EP16K
Hello, Friends
I have a big trouble with my truck { EP16K. S.N. ETB6A - 00345}. firstly the truck gives bad brushes for drive motors... I solved this problem , after that give error 60.... cut off and cut on again the truck seems OK, and then The display light but no data no digits.. cut off and cut on again the truck seems OK.Then , after minutes line cont. open and error 61 appear in display. cut off and cut on again the line cont. open , forklift does not work and Display appear no data no digits... I don`t understand what happened.
I don`t know what to do.
Any help would be appreciated
Thanks
Power7
  • Posted 28 May 2010 22:51
  • By power7
  • joined 4 Mar'10 - 7 messages
  • kaluobia, Egypt
powerlift7@gmail.com
Hello, Friends
Thanks for Ur advices
The D1 in logic card is damaged.. I replaced it, then the forklift working normally over 20 hours.. After that give me ERRORS 60 ,61, 51. and i know it`s not a true fault because i replaced a display, ACC., the battery and no change.
After that i replaced the original parts back to the forklift..
the display give me [ dead], i don`t know what is that mean
I`m afraid.. If i purchased a new logic card and the problem still exist..?! it`s a lot of money you know.
I don`t know what to do ?. But i appreciate your help, really i do.
Thanks
Power
  • Posted 7 Jun 2010 08:44
  • By power7
  • kaluobia, Egypt
it's also a real possibility that you have the wrong eeprom installed in the logics. does the number on the new eeprom on the new logics match the number on the old eeprom on the old logics? the eeprom PN (and related programming) are different for different options on the truck so if the logics has an eeprom for a contactor type hydraulics and the truck is a chopper type hydraulics, or a different voltage, you will get an error about like this.
  • Posted 30 May 2010 21:17
  • Modified 30 May 2010 21:19 by poster
Error 61 can also require you to carry out a factory reset, as it can indicate that the EEPROM has lost its settings. As AMartins has said, everything is possible.
  • Posted 30 May 2010 17:41
  • By AndyPandy
Hello my friend. I know how these problems, but have seen the links in the battery elements, ie between the jumpers are for tightening screws, and plugs connection. ever happened to me with another similar type of machine, it was bad connection in the battery. also had ties oxidized. My friend everything is possible.
  • Posted 30 May 2010 07:11
  • By AMartins
  • joined 8 May'10 - 107 messages
  • vila nova de gaia, Portugal
Hello, Carl
I`m grateful for your generosity
I had replaced a display and no change... logic card and no change and the wiring btw. display and logic card is ok.
I wonder , is a H - Bridge card make this problem?!
I don`t know. waiting for your advice
P.S. May be you send to wrong E- Mail.
Thanks
Power7
  • Posted 29 May 2010 03:55
  • By power7
  • kaluobia, Egypt
60 = a)communication problem between logic and display b)bad display c)logic unit d)low resistance between components and frame of truck
61 = eeprom abnormality with possibly leads to logics
Check your email, items attached that should help
  • Posted 29 May 2010 02:18
  • By carl_v
  • joined 12 Oct'07 - 76 messages
Big Joe PDR30-154
USD7,500
Tusk 500PGH16
Spencer/Sheldon/Sioux Rapids, IA, United States
Big Joe PDR30-154
USD7,500
Tusk 500PGH16
Lee Rushton Lee Rushton
