cat ep15t
help have cat three wheel cb ep15t ser2nm01744, got stuck in hole in yard , blew resistor on driver card , replaced card same resistor smoked , found one of the trn transistor packs faulty , have replaced both trn modules , have lift, steering , only drives one wheel really slow , all contactors ok , possibly driver card damaged ? or further problem need info please ,, thanks guys
  • Posted 14 Jul 2012 16:35
  • By trevb
  • joined 10 Jan'12 - 157 messages
  • avon, United Kingdom
monday is the longest day
hi guys , ran through tests etc smoked another transistor pack , replaced driver and transistors again held breath and turned on , now works fine thanks trevorb at solutionmhe dot com
  • Posted 26 Jul 2012 07:12
  • By trevb
Hi Trevb, post me your email and I'll send the manuals to you on the mircocommand system fitted to your truck
  • Posted 20 Jul 2012 04:03
  • By nigel_w
  • joined 19 Feb'12 - 8 messages
no flashing fault codes showing only 9 on display i presume is battery percent , i presume h bridge is inside the long black case behind the contactor rack , only have little knoledge of this truck , have turned steering to left right that drops out motor which is turning slow could do with manual if any one has one thanks for help
  • Posted 16 Jul 2012 07:18
  • By trevb
if the steering wheel sensor reads straight ahead, and you only have 1 wheel getting traction power, (with all the other info) you may have a bad motor and/or bad "h-bridge" card.
does the dash give any errors when you try to drive??
  • Posted 15 Jul 2012 22:23
Yes does sound like a problem with the driver card. If the transistor has been replaced also advisable to replace driver card.
Any error codes?
  • Posted 15 Jul 2012 07:59
  • By elektrodrive
enquiries@elektrodrive.co.uk
F. Uchiyama
F. Uchiyama
