CAT DP40 3CM1100 Hydraulic Pressure Measurements
Truck has 8,000 lbs capacity but cannot lift more than 5,000 lbs. Does someone know what the press readings on hydraulic valves should be on CAT DP40 3CM1100? Same with pump measurements.
Thanks,
OB1
  • Posted 26 Jan 2014 01:55
  • By ob1kenobi
  • joined 22 Nov'10 - 153 messages
  • SAN P.SULA, Honduras
Cheers!
Thanks gc_d !
  • Posted 30 Jan 2014 00:35
  • By ob1kenobi
on the left side of the valveblock in the elbow of the pressure pipe from pump. it is a 1/8 inch plug.
  • Posted 29 Jan 2014 00:48
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
Thanks! Do you know the Press test points?
  • Posted 28 Jan 2014 02:41
  • By ob1kenobi
Cheers!
Hi , check first the overload valve..
  • Posted 28 Jan 2014 01:52
  • By gc_d
Regards gc_d
main relief setting is 2773 psi on a DP40k
  • Posted 26 Jan 2014 12:26
  • By jeremy_s
  • joined 28 Mar'08 - 205 messages
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
Yale Lift Truck Technologies
