cant figure out the year
I can't figure out the year of this forklift. Serial number is only 7 digits. Y431231 Everything i read says it should start with an N if it is pre 2000. Any help would be appreciated.
  • Posted 19 Jul 2023 06:46
  • By Randy_Horsley
  • joined 19 Jul'23 - 1 message
Randy,
I made a mistake originally. The year of this lift is 1986. The Y in the serial number I believe is a designator for where it was built. I am not able to find what it stands for. Thanks.
  • Posted 19 Sep 2023 21:37
  • By Fishmech
  • Virginia, United States
CORRECTIONS and CLARIFICATIONS: "C" in the CB pair is a "special model designator," and "B" in the CB pair is the "design series" according to Yale.
"U" is the designator for the Mazda UA engine. "A" is the designator for an AUTOMATIC transmission. But as far as I can tell neither Yale nor anyone else at that time was using a manual transmission for machines this small. I did have to use a well-used-and-on-its-last-legs manual transmissioned Yale in a warehouse setting back in the mid-1970s and that made for a pretty miserable work day.
Either E" or "T" mean triplex mast.
Hope that clears things up.
  • Posted 19 Sep 2023 06:13
  • By Toaster
  • joined 5 Sep'23 - 4 messages
Yale uses 23 letters of the alphabet to designate the year in the serial number. When they get to the end of the alphabet, they start over. The letter "Y" is either a 1978 or a 2001. That model number was made in 1978 but not 2001. So it is a 1978. By the way, your serial number is not too far from my own.
The "GLC030" part of the model number tells us this is a LP fueled, cushion tire forklift with a 3000 lb lifting capacity. The "C" narrows it down to a part of the model run and the "B" further narrows it down to a particular part of the "C" portion of the model run. "J" means it was made in Japan. "UA" means it has a Mazda UA engine. the letter "E" designates the type of mast. I think "E" means triple mast. And finally, "083" is how tall the mast is in inches when at rest
  • Posted 16 Sep 2023 20:13
  • Modified 16 Sep 2023 20:17 by poster
  • By Toaster
Randy,
This lift would have been built in 1993 or 94. Thanks
  • Posted 29 Jul 2023 04:26
  • By Fishmech
Terberg YT182
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
edition #1284 - 4 June 2026
It has been a big week of product launches for the materials handling sector... Continue reading
Ancient Egyptian civilization lasted for so long - over 3,000 years - that by the time of the New Kingdom (c. 1550-1070 BCE) Ancient Egyptian archaeology was a career option.
