Cam sensor code
Reman engine sensors and modules the same. Cam code showing 520800-07, 4.3l no cam sensor. Suggestions?
  • Posted 14 Feb 2024 02:33
  • By Lucky11_H
  • joined 14 Feb'24 - 4 messages
  • Kentucky, United States
Lucky66h
Lucky,
You state reman engine, did the original engine have a cam sensor? If so did the reman come with one? If you had one in the original and not in the reman, will need to install sensor into reman if possible. If not, need to replace reman with correct engine. 4.3's are funny. Depending on the year, multiple things need to be checked when installing a reman. If yes, check to make sure it is connected. If it is, make sure wires were not cut during installation or you may have a failed pin inside the connector. Good Luck.
  • Posted 20 Feb 2024 02:58
  • By Fishmech
  • Virginia, United States
Toyota 3FD100
Maxlion FD30
