c5000 e-27
Im working on a cat c-5000 that giving me an e-27 code i have never seen this before and ideas
  • Posted 28 May 2008 00:15
  • By jake_k
  • joined 28 May'08 - 2 messages
  • Kansas, United States
you forgot after 10seconds and code appear hold pedal to floor to clear
  • Posted 25 Dec 2016 02:02
  • By billy_k
  • joined 24 Dec'16 - 10 messages
  • Rhode Island, United States
if you successfully enter into the diagnostic mode to clear the codes using the pedal dance and the code does not clear then your problem is still there. You have to have the problem repaired before the code will clear or it will just set itself again.
How do you know you've successfully entered the diagnostic mode after the pedal dance? You will notice the flashing lights change and the engine light (MIL) will flash out of sequence with the others and also the hour meter will show up umong the code that is flashing in the LED display, generally when in error display mode the hour meter reading is hidden.
  • Posted 5 Sep 2012 20:37
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
Hi i have the same problem and it show the E34 i don;t know about the E34 code i use the isntruction that you submit put it dosen;t work on my c500 do yuo have any other idea
  • Posted 5 Sep 2012 07:16
  • By JHpantaleon
  • joined 26 Jun'10 - 13 messages
  • distrito, Dominican Republic
TRY:
Key on:
Wait 3 second (use long count like 1 mississippi,
2 mississippi, 3 mississippi or stop watch.
Off pedal 7 seconds (Long count)
On pedal 10 seconds (Long count) hour meter should appear at 10 sec. mark then start fluxuating between code and meter, wait till excamation ( ! ) quits flashing then key off, then restart truck.
You can also try to disconnect battery negitive and wait 1 minute.
When you do the pedal dance make sure the floor board is back on truck.
If the code was for brake light switch, do the dance with the other foot pushing down brake pedal, not inching.
  • Posted 21 Mar 2011 04:43
  • By BenH
  • joined 17 Aug'09 - 27 messages
if anyone does have that information, they would need you to put a good e-mail address in your profile (not in the forum), to be able to contact you.
  • Posted 17 Mar 2011 10:12
i would like to know to to clear that flashing dash light after i change bad ignitor
  • Posted 17 Mar 2011 09:46
  • By phillboy
  • joined 5 Mar'11 - 7 messages
  • New Jersey, United States
TILT WIILL NOT STAY , KEEP GOING FORWARD WHEN LEVER IS PULL BACK
So after I have replaced the plugs and wires how do I clear this code
  • Posted 16 Dec 2010 01:36
  • By Navyman
  • joined 16 Dec'10 - 4 messages
Check out ignition system.Every time I see this code a tune up has taken care of problem
  • Posted 21 Jan 2010 23:01
  • By proshadetree
  • joined 23 Feb'06 - 484 messages
  • Tennessee, United States
jake,
i have just got this e27 on a c5000.
what did u do to solve this?
  • Posted 23 Aug 2009 01:18
  • By hellokitty
  • joined 11 Mar'09 - 86 messages
Thanks alot carl v
  • Posted 31 May 2008 00:32
  • By jake_k
E27 relates to crankshaft position sensor. Have seen this code set because of misfire of sparkplug, coil pack or wiring to coil pack.
  • Posted 31 May 2008 00:03
  • By carl_v
  • joined 12 Oct'07 - 76 messages
GemOne
