Clark C500 SERIES:
C500-60 just got yesterday...have one question
As a prior c500-45 owner I am very familiar with clark trucks...however, the one I got yesterday is newer than mine. It has the one lever on the right side of the wheel that controls everything on the mast. It goes up, in, and out just fine...but it goes down slower than a 7 year itch lol. Looks to me like something is worn out in the shaft that it pulls on. Is this a common problem? You have to push the lever down, but its on a pivot and it actually pulls a rod up through the inside of another one. Any ideas?
  • Posted 3 Aug 2010 01:08
  • Discussion started by DickeyeFab
  • Missouri, United States
The bubbles are common and is just compression pushing past the plug. It might stop by tightening the plug a bit. Denso L14U is the plug. Also great advice on your lowering problem. Often after I loosen the Allen head bolts on the clamp on the steering column I will put some Red Loctite beneath the clamp before tightening up.
  • Posted 9 Sep 2012 14:34
  • Modified 9 Sep 2012 14:35 by poster
  • Reply by Forkliftt
  • Louisiana, United States
Steve
steve at forkliftt dot com
Ok thanks! I will check that out tonight. I do have two other issues now...it gets really hot in a matter of minutes...boiled out some coolent last night. So I washed it off and noticed that I had gotten the head wet and there was water around the spark plugs....and it was bubbling around 4 of the 6 while it was running. Anyone know what kinda plugs its supposed to take? It has a Autolite 45 right now.
  • Posted 6 Aug 2010 00:47
  • Reply by DickeyeFab
Yes that's a common problem. That clamp that holds the whole linkage to the steering column may have slipped out of adjustment (2 allen head bolts half way down the column). Try loosening it and sliding it up to take up any free play. It is just a matter of adjustment. There should be a panel in the front part of the machine (4 bolts) to access adjustments also.
  • Posted 3 Aug 2010 06:11
  • Reply by mrfixit
Jospeh E Creed Jospeh E Creed
CEO, Caterpillar Inc
Secretary general, European Rental Association
Chairman of the Board of Directors, UgoWork
Hyster-Yale reports Q1 revenue fall Cleveland, OH, United States
UN Forklift FD40T
Toyota 02-8FD30
