C500-55 tilt cylinder removal
How do I go about removing the rear pins on the tilt cylinders?
I have removed the horizontal pin and see the flats on the inside qhere the grease fitting is Does this mean they thread in or are they just stuck and need a little KROIL persuasion?
Thanks
  • Posted 1 Nov 2023 15:51
  • By Doug_Baker
  • joined 1 Nov'23 - 3 messages
  • Michigan, United States
No problem, glad you got it !
  • Posted 11 May 2024 04:14
  • By John_Bradley
  • joined 10 Aug'22 - 253 messages
Jb69
Hi John, I finally got around to fixing my tilt cylinders and really appreciated your help and advice. Thanks again, Doug Baker
  • Posted 11 May 2024 03:21
  • By Doug_Baker
Hi John, mine only had a cotter pin pushed into the hole to retain the pin. Sorta figured that wasn't factory. ??
Don't see where to get between the frame and clevis as its welded to the side rail do you mean use the heel bar on the head where the grease fitting is?
Call me if you wish at your convenience at 248-789-4323 and I csn send a few pictures if I have to. Thanks again, Doug
  • Posted 3 Nov 2023 06:52
  • By Doug_Baker
The pins should have a ring around them that a flat piece of metal fits in that is held in by a bolt once you remove these then take a heel bar place against frame and push pin out far enough to grab with a big pair of channel locks then pull pin out.if the unit wasn't greased regularly the it may be a little tougher
Once the pin is out put a bar under back of cyl and pry it up and out of the cradle
  • Posted 3 Nov 2023 06:08
  • By John_Bradley
Jb69
In May 2023, a Belgian Malinois named Wilson played a key role in the rescue of four children lost in the Amazon jungle. The young children were missing for 40 days after a plane crash that killed their mother and other adults. Wilson tracked the children's footprints, leading the military to their location.
edition #1248 - 18 September 2025
October 15-16, 2025 - Amsterdam, United States
October 15-16, 2025 - Las Vegas, United States
June 30 - Jully 2, 2026 - Birmingham, United Kingdom
ASSET FINANCE
Nov 2025
JLG G12-55A
Toyota 8FGCU25
Flesherton, Ontario, Canada
ASSET FINANCE
Nov 2025
