BT RRB6 error codes C16 C17
Hello again :)
I missed the service manual for BT RRB6 and i have problem with one of these machines. Can someone "translate" me the error codes C16 and C17. (SN 708211 year2004) I guess one of them maybe is service maintenance time.. but im not sure.
Please help!
Thanks in advance!
  • Posted 11 Feb 2013 22:34
  • Modified 12 Feb 2013 01:05 by poster
  • Discussion started by mhonotone
  • Sofia, Bulgaria
Showing items 1 - 15 of 15 results.
Found error codes on BT
https://www.truck-freeworkshop.com/bt/bt-fault-codes/
  • Posted 27 Nov 2021 02:10
  • Reply by Antero_Bux
  • Bosnia and Herzegovina
C26 = Input stage error.
Check the error log as it will pinpoint which input it is with a logged code but I would suspect a hydraulic joystick isn't in the neutral position at start up - normally a bic biro is the cause.
  • Posted 12 Dec 2018 03:42
  • Reply by Forkingabout
  • england, United Kingdom
Need help!!!
Any idea on the error codes C26 on start up?
Thank you
  • Posted 11 Dec 2018 15:17
  • Reply by CamFork
  • Cambodia
great
  • Posted 29 Sep 2018 23:51
  • Modified 29 Sep 2018 23:54 by poster
  • Reply by niroli_z
  • France
Will do. Just to let you know, I wrapped the path to the template file in normalizePath and now it works perfectly. So it does seem that the path was the problem. On a related note, I had the same issue with addImage() and I used normalizePath there too. I mention this in case this issue shows up other places.
  • Posted 29 Sep 2018 06:37
  • Reply by niroli_z
  • France
mostly is spring in brake pedal broken.The pedal give in neutral a higher voltage to a5 board than it is calibrate before starting with drive then it generate a fault. you can fix it easy.If you have again the error you need calibrate the pedals. You need truck program or cankey
  • Posted 19 Sep 2018 21:14
  • Reply by gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
Mhonotone you said you have fixed the fault,
what did you do to repair C16 C17 on pedal press.
  • Posted 19 Sep 2018 09:52
  • Modified 19 Sep 2018 09:56 by poster
  • Reply by Onsite
  • New South Wales, Australia
Lifting Services to new Heights
A5 card internal battery low voltage.
  • Posted 2 Aug 2018 21:54
  • Reply by tasos_t
  • ATTICA, Greece
Any ideas on c018?? BT rrb2
  • Posted 31 Jul 2018 20:39
  • Reply by dan_r
  • West yorkshire, United Kingdom
C028 = Emergency stop switch activated.
Or the emergency stop circuit has detected a fault.
  • Posted 4 Jan 2015 18:46
Hi
I need a little help. BT machine is throwing an error code C028.
Can anyone tell me what this error code is.
Thanks
  • Posted 4 Jan 2015 17:15
  • Reply by angie
  • Western Cape, South Africa
I've already fix it... without cankey. i was just needed the info about the error codes because i dont have the service manual of this machine ;/
Thanks a lot again!
  • Posted 13 Feb 2013 01:25
  • Reply by mhonotone
  • Sofia, Bulgaria
Are these codes happening at start up OR when the truck is being driven?
Also check the spring under the brake pedal as these do snap after a while allowing the brake pedal to go out of calibration.
  • Posted 12 Feb 2013 19:38
Thank you nacsand_n! I appreciate your help. (bow).
  • Posted 12 Feb 2013 17:45
  • Sofia, Bulgaria
No, this codes are not the service reminder.
C16 indicates accelerator potentiometer voltage is out of range
C17 brake potentiomer voltage out of range.
Make sure both pedals are not actuated on start up the truck, but I think you need to do a brake and accelerator potentiomer calibration through parameter nº38, but will need the service CANKEY
Regards
  • Posted 12 Feb 2013 01:38
  • Reply by nacsand_n
  • Madrid, Spain
Bolzoni SpA (Group HQ)
Wentzville, MO, United States
Ottumwa, IA, United States
Harrisburg, SD, United States
UN Forklift FGL25T
Hangcha CBD15
China
USD1,600
edition #1235 - 19 June 2025
