Bt prime mover RTX35 Aisle Lift E102
First post a fellow tech turned me on to this Forum! I have an Error code 102 "Drive Transistor Regulator Internal Error" LED 4 (red) "Fault In Reference Value Circuit" that is giving me fits. I have run through the diagnostics in the manual for the problem to no avail. All the values are within specs. The symptoms are: When going forward or backward the lift locks out (E102). If you very slowly accelerate you can some times get to full throttle without lock out. With the drive wheel jacked up off the floor (no load) you can can accelerate through the full range forward and back without it tripping a code and locking out. Any help would be much appreciated!
  • Posted 9 Jan 2014 00:18
  • By quahog
  • joined 8 Jan'14 - 3 messages
Still had the issue after replacing the worn out motor brushes. Embarrassingly enough the culprit turned out to be the battery! Got ahead of myself and didn't check the basics first. Thank you for the help!
  • Posted 16 Jan 2014 22:55
  • By quahog
Sounds like the same basic design of controller BT use on the old DC stuff in Europe.
I'd physically double check the traction fuse as I've seen issues with burnt fuses causing odd throttle issues even though a multimeter says the fuse is fine, I have also seen these type transistor panels burn transistors out.
Have a sniff of the panel, if it smells burnt you then need to investigate further.
There is only 4 self tapping screws on the back of the panel that holds the plastic top on - be warned that opening the unit normally voids any warranty / service exchange return in the future & mind the capacitors inside!
As I said before we don't get to see the Prime Mover stuff over here in UK but it sounds like it's a basic BT parts bin DC equipped machine.
  • Posted 10 Jan 2014 04:45
  • By Forkingabout
  • england, United Kingdom
Yes it is a 24V DC Machine. It is a stand up aisle lift, it uses a "joystick" type throttle not a pedal. I don't know if it is Atlas Copco but the drive transistor is in fact grey with the LED's you mentioned. The brushes in the drive motor are quite worn so we will replace them first and retest. Thank you for taking the time to reply!
  • Posted 10 Jan 2014 01:26
  • By quahog
Is this a DC machine?
We don't really see the Prime Mover stuff here in Europe but from what I gather bit's of it are based / used on the older BT machines.
If it is a DC machine & if it is the same drive system as BT Europe use I'd check the microswitch inside the throttle pedal assy as the roller wheel can get a flat spot & cause odd issues like this.
Is this the grey Atlas Copco transistor regulator with 1 green, 1 yellow & 2 red led's fitted?
  • Posted 9 Jan 2014 02:01
  • By Forkingabout
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
Enforcer FLBAXT25
Hangcha FLDCXT160
Toyota launches three new stackers Columbus, IN, United States
Orlando area, United States
Highland, IL, United States
Tacoma, WA, United States
Dallas, TX or Lexington, KY, United States
