BT LWE 130
I have a BT minimover LWE 130 S/N 6066732 YOM 2008
Zappi Semex controller lift pump runs OK battery good but drive motor runs slow on the floor or when jacked up.Any input would be greatly appreciated
  • Posted 22 Dec 2011 02:37
  • By nick_c
  • joined 17 Jun'11 - 116 messages
  • south glos, United Kingdom
Hi where is the location F1 and F2 shorting
And what is a chopper?
  • Posted 25 Nov 2023 05:51
  • By Philip_Leung
  • joined 25 Nov'23 - 2 messages
  • Netherlands
Philip leung
Hi did you solved the problem with the bt lw130
I have the similar problem lift good but when in drive is run slow
  • Posted 25 Nov 2023 05:49
  • By Philip_Leung
  • Netherlands
Philip leung
thanks Nick I did check the fuses both were good. one thing I did notice is the key is broken in the on position and cant be turned off for charging... is it possible that this will cause the no charging concern??? Thanks so much for getting back to me on this...
Cheers R...
  • Posted 10 Apr 2014 02:32
  • By Styx
  • joined 31 Mar'14 - 23 messages
  • British Columbia, Canada
Hi Randy. There are 2 blade fuses under the cover, one of those are for the charger 10Amp see email for fault LEDs
  • Posted 9 Apr 2014 17:20
  • By nick_c
I have one of those btminimover model HWE100S
# 6020254/2007 It won't charge. Any places i should be looking???
Email [email address removed]
Thanks in advance...
  • Posted 9 Apr 2014 08:07
  • By Styx
Thank you for your help!
The problem was a short circuit between f1, f2 and chassis.
The chopper breakdown but I have had one in my van!
  • Posted 28 Nov 2013 09:30
  • By fernando_m
  • joined 9 Apr'13 - 21 messages
  • Barcelona, Spain
Check your email
  • Posted 28 Nov 2013 03:52
  • By nick_c
I just added the email to my details.
sorry for the big delay I was of sick.
  • Posted 27 Nov 2013 16:00
  • By fernando_m
  • Barcelona, Spain
Fernando
give me your email address or put it on your profile Nick
  • Posted 9 Apr 2013 17:01
  • By nick_c
Hi guys,
I have one of those machines with problems, mine has the pump working perfect but no traction at all.
I have been testing the battery and its fine, the tiller switch works and the contractor kicks in the coil in the brake receives 24v but no movement after that.
I tried dismounting the brake but still the same, the problem is that I don't have any info about this truck, any ideas???
Thanks so much bye !!
  • Posted 9 Apr 2013 15:10
  • By fernando_m
  • Barcelona, Spain
I remember that this pallet truck in olders machines slows down when driving and if at the same time pump is active. Check lift swicht S34.
I send you some information in spanish, check your mail.
Regards
  • Posted 22 Dec 2011 04:46
  • Modified 22 Dec 2011 05:01 by poster
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
Is the service warning flashing?
There is a parameter that if its activated will slow the truck down if the service warning isnt reset.
  • Posted 22 Dec 2011 03:15
  • By Forkingabout
  • england, United Kingdom
Deborah Baker Deborah Baker
