BT Fault 2.511
BT truck shows fault code 2.511. Please give the solution against the fault code.
  • Posted 28 Apr 2019 22:07
  • Discussion started by mdmanik
  • Gazipur, Bangladesh
Aquí está una traducción literal del código de error proporcionado a continuación
2.511
El contactor principal está abierto.
Error de comunicación CAN.
Compruébelo:
*conexiones y cableado
*cables 119 y 120
*Tarjeta de lógica en el mango del brazo del timón.
Here is a literal translation of the error code provided below
2.511
The main contactor is open.
CAN communication error.
Check it:
*Connections and wiring
*cables 119 and 120
*Logic card in the rudder arm handle.
  • Admin
  • Posted 7 Aug 2020 12:10
  • Modified 25 Oct 2020 15:05 by poster
  • Reply by Admin
  • Queensland, Australia
hola estimado , llegastes a encontrar el fallo , ya que hoy se nos presento este codigo en un BT , podrias compartirmelo. saludos desde peru
Literal translation - hello , we have the same error code on a BT, could you share it with me. greetings from peru
  • Posted 7 Aug 2020 09:10
  • Modified 7 Aug 2020 12:04 by administrator
  • Reply by ricardo
  • Peru
2.511
Check:
*connections and wiring harness
*cables 119 and 120
*logic card in tiller arm handle.
  • Posted 13 May 2019 11:28
  • Reply by luke_k
Model:SWE 120L Serial: 6108838
  • Posted 2 May 2019 23:35
  • Reply by mdmanik
2,511
The main contactor opens.
To check:
* connections and wiring
* cables 119 and 120
* logic board contained
in the handle of the rudder.
  • Posted 30 Apr 2019 20:46
  • Reply by mirko_c
  • Reggio Emilia, Italy
Model and serial?, controller brand?
  • Posted 29 Apr 2019 02:45
  • Reply by prepaito_d
  • iztapalapa, Mexico
Komatsu FD25T17
Mobicon 2T
