Bt C4E200 service manual
Hi,
I am looking for help with a BT C4E200 or possible fault code description and schematics.
Fault codes 08 & 68
Any help is greatly appreciated
  • Posted 11 Sep 2014 05:12
  • Modified 11 Sep 2014 17:57 by poster
  • Discussion started by Smithers
  • Yorkshire, United Kingdom
Regards lee smith
Hi Frits,
Am looking for help with error code 2A.
Regards.
  • Posted 22 Mar 2020 22:17
  • Reply by Eric_Mwas
  • Kenya
Thank you Frits I will try.
  • Posted 15 Sep 2014 18:52
  • Reply by Smithers
From the manual:
08 K1 contactor failure. The contactor is supplied bot the contacts not close. Check the coil (100 ohm) and the relevant cables. Check the contacts.
68 same as 08; 08 is from master traction module. 68 is from slave traction module. So same fault detected by 2 different modules.
You might have a stuck or corroded main contactor
  • Posted 12 Sep 2014 17:59
  • Reply by frits_f
  • utrechte, Netherlands
F. Uchiyama
Hyster
Wentzville, MO, United States
Harrisburg, SD, United States
Ottumwa, IA, United States
