brakes staying on
we have a combilift 3.0 cb and the brakes are staying on, has anyone any idea where we would begin to identify the issue, we have been told to check the inch valve.
  • Posted 25 Mar 2017 05:23
  • By harry_c
  • joined 25 Mar'17 - 1 message
  • CO ARMAGH, United Kingdom
did you check the brake pressure at the brake line on the motor?
I would put a pressure guage inline on the brake circuit and see if the pressure is dropping when it gets hot.
check the fitting on the hose connection.
diagram shows brake line to RH motor and then to LH motor.
If LH motor is releasing then something is either wrong with the brake unit on the RH motor or its not pressurizing the brake servo.
  • Posted 28 Nov 2019 14:51
Maybe you can help me out. I have a combi C6000CB. After the truck gets hot the wheels lock up. I have to wait for the machine to cool down before it starts moving again. We replaced some relays, one of the changeover valves and the right side drive unit since the right side is the one locking up. After changing all these parts, the wheels are still locking up. Any suggestions as to which direction to go from here?
  • Posted 28 Nov 2019 09:13
  • By HiloPro
  • joined 28 Nov'19 - 3 messages
@HiloPro
yes sir i am :oD
  • Posted 28 Nov 2019 08:55
  • Modified 28 Nov 2019 08:55 by poster
Swoop223 are you still on this forum?
  • Posted 28 Nov 2019 05:32
  • By HiloPro
if this is the CUBE model:
you can check the inching valve for sure but also check the parking brake switch and circuit at the dash controls and make sure it is correctly working, no broken wires etc. Also there may be a switch under the left pedal that operates the brake circuit.
also there is a brake valve associated with this circuit located at the hydraulic tank filter line
If a CB model then there should be a brake valve under the floor plate area (left pedal), it is not an inching valve, its either on or off. This valve is a manual valve that works the brake units on the motor assys releasing them when the pedal is actuated.
  • Posted 21 Jun 2017 23:48
  • Modified 21 Jun 2017 23:50 by poster
Inching valve could be an issue, look under the door in that open space with all the hoses, top left under the pedal is the valve, couple JIC stuck out of it with hoses runnin off it as well as a return spring for the pedal its self, check to make sure it's operating, i've only come across them leaking, not stickin so not much more help then that.
  • Posted 21 Jun 2017 01:52
  • By ryan_t
  • joined 12 Apr'17 - 28 messages
  • Newfoundland and Labrador, Canada
edition #1285 - 11 June 2026
Crown names top North American dealers New Bremen, OH, United States
Stu Jacover Stu Jacover
Chief executive officer, TVH
Mitsubishi FD200
SMV (Konecranes) 12-1200B
