brakes lock up
On this Hyster H 50 XL after operating the lift for about 30 minutes continuously, the brake drums get very hot & the brakes lockup. After allowing them to cool the lift can continue for a short while then will lock up again. This only happens when using to unload a full semi. Normal warehouse use does not cause them to lock up' I am wondering if there is brake fluid accumulating in the brake system that is not bleeding back to the master cylinder due to the higher number of times the brakes are applied during the unloading process. And what in the brake system could cause such a restriction? There is lots of pedal & the brakes stop it fine until they lock up then they stop it too well.
  • Posted 22 Jun 2015 03:48
  • By doc2
  • joined 22 Jun'15 - 5 messages
A forklift 4 u.
Thank you very much, it had no play at all. I adjusted the play as you suggested & operated it under extreme working conditions for over 45 minutes without the brakes locking up. Great advice
  • Posted 22 Jun 2015 22:39
  • By doc2
A forklift 4 u.
you need to insure the push rod into the master cylinder has a bit of free-play when the brakes are released (1/8 inch)
  • Posted 22 Jun 2015 08:23
Toyota 02-2TD20
Maxlion FDR45
edition #1267 - 5 February 2026
In this week’s Forkliftaction News , we report on the January Logistics Managers' Index - a bellwether of the US logistics sector - which has jumped 5.4 points in a month, below the all-time average but still indicative of consistent growth... Continue reading
Goldfish are opportunistic feeders that have no stomach and lack that natural "fullness" signal. This means they will eat constantly if food is available, leading to serious health issues such as blocked intestines and obesity from overfeeding.
Cincinnati, OH, United States
St. Louis, MO, United States
