Bleeding off propane
Can anyone tell me how to bleed out the system so i can change the propane filter ('87 Yale GLC050 FE mazda engine)
  • Posted 7 Oct 2011 00:43
  • By schuyler_d
  • joined 29 Sep'11 - 1 message
That is the correct way to bleed out an LPG line. If the truck does not run you can crack open a LPG fitting.......NO SMOKING.......
  • Posted 7 Oct 2011 22:17
  • By Prentice
Don v;
The equipment manufacture's and also the NFPA instructions are "Close tank ***, start and run engine, and then consume LPG in the fuel line, engine will stop, diconnect fuel line from tank using Personal Protective Equipment." After finishing work reconnect fuel line to tank using PPE, open tank *** - slowly - and start engine, check for LPG leakage using soapy water after assembly.
  • Posted 7 Oct 2011 09:27
  • By MEngr
  • Missouri, United States
Safest is to disconnect the tank and run the truck till it shuts down.
  • Posted 7 Oct 2011 04:13
  • By don_v
  • joined 6 Oct'11 - 1 message
  • Wisconsin, United States
Regards...........Ducky
I usually push in the valve at the propane connector with the rubber coated handle of a pair of channel locks. Just make sure it's pointed away from you. Or you can crack open one of the lines at the lock off.
  • Posted 7 Oct 2011 01:37
  • By joe_d
  • joined 25 May'10 - 253 messages
Ain't nothing I can't fix but a broken heart and the break of day!
Kai von Berg Kai von Berg
SMV (Konecranes) SL37-1200A
JLG G12-55A
