BAKER FORKLIFT
I have a Baker forklift and can;t find out any information about it. a tag of "C9020Y9" is all I can find can anyone help
  • Posted 24 Feb 2015 03:08
  • Discussion started by SCOPEGUY
Showing items 1 - 15 of 17 results.
Was wondering where you got your manual for this unit. Does your unit have a air cooled diesel engine. And is it a parts manual also?
  • Posted 1 Aug 2021 01:53
  • Reply by George_Quiroz
George Q
George Q
I would like to thank the people who helped me work this project out. With your help I found a manual about this truck and now it's the best toy in my toy box. Thanks again
  • Posted 20 Mar 2015 00:28
  • Reply by SCOPEGUY
Found two sets of numbers #78674 and #1380_7 can't read the 5th number in the second group.I also adjusted the stop on the brake/realse valve[for disengauging the transmisson] and the truck pulls really good now.pULLED THE TIRE OFF TO MEASURE THE BACKSPACE and the weight was 187lbs. so I think its a solid tire can I change over to a regular tire
  • Posted 14 Mar 2015 01:07
  • Reply by SCOPEGUY
Your forklift truck is absolutley an FJF model. You may have seen a photo of a previous version. Baker forklift trucks were made by series. Most likely this is an 1860 series.
I would not recommend sandblasting a forklift truck. It could contaminate the hydraulic system and then you would have some issues.
  • Posted 14 Mar 2015 00:27
  • Reply by duodeluxe
  • United States
duodeluxe
MY MISTAKE JUST GETTING OVER THE FLU, THE FLUID IS RED AND FOUND A RELIFE VALVE HOOKED TO THE BRAKE PEDEL ASSM. WILL TRY TO ADJUST IT AND SEE IF IT HELPS. THE CARRAGE IS 16" WITH PHEM. 15" FRONT TIRES, GAS 6 CYL.FLAT HEAD CONTIN. MOTOR HAVE LOOKED AT A PICTURE OF A FJF-040 AND LOOKS NOTHING LIKE MINE. WILL SANDBLAST MORE OF THE FRAME TOMORROW LOOKING FOR NUMBERS
  • Posted 13 Mar 2015 03:13
  • Reply by SCOPEGUY
The carriage is the item that the forks hang on.
The transmission in this truck is pretty strong and very simple. The fluid should be red. Even if it is 2 quarts low it would affect the proper functioning of it.
  • Posted 12 Mar 2015 02:45
  • United States
duodeluxe
Definitely an FJF series with a torque converter transmission and LP Gas powered flathead Continental engine.
Serial numbers were stamped in the LH side top of the frame right where the operator places their feet to get in/out of the truck. Usually worn off or very difficult to find or read.
Transmission used Dextron ATF which is red in color. Sounds like the transmission may be slipping and someone filled it with some kind of heavier type oil to try and compensate for wear.
Good luck on finding the serial number
  • Posted 11 Mar 2015 16:45
  • Reply by StarTrip55
What is the carriage,the part that holds the forks.Sandblasted the dash surrport top to bottom,no numbers. also the truck does not pull hard could the trans oil be the wrong weight or type it's yellow?
  • Posted 10 Mar 2015 09:28
  • Reply by SCOPEGUY
The carriage can't be 22" from top to bottom. It is most likely 16"
The numbers are stamped on the outside next to the floorboard towards the front of the forklift truck. You are not looking hard enough.
  • Posted 27 Feb 2015 06:58
  • United States
duodeluxe
The carrage is 22" high. are the numders on the inside of the cab or are they on the outside?
  • Posted 27 Feb 2015 06:52
  • Reply by SCOPEGUY
What is on the side....?
The truck is a model FJF040,050 or 060. If the carrrage is 16" from top to bottom then it either has a 4000# or 5000# basic capacity. If the carriage is 20" then it has a basic capacity of 6000#.
The serial # should start with a letter followed by 1860-... or 1930-...
  • Posted 27 Feb 2015 00:54
  • United States
duodeluxe
This is on the side of the dash support on the inside of the frame? Couldn't find out how to send a photo so I used my avatar
  • Posted 26 Feb 2015 12:10
  • Reply by SCOPEGUY
is this any help
  • Posted 26 Feb 2015 02:00
  • Reply by SCOPEGUY
Can you post a photo of it? The serial # is definitely stamped in the frame near where I said. It should either start with 18.... or 19...
  • Posted 25 Feb 2015 10:23
  • United States
duodeluxe
Taylor TE650S
Hangcha CBD15
China
USD1,600
Noblelift
Wentzville, MO, United States
Harrisburg, SD, United States
Ottumwa, IA, United States
