Baker - B-30-CE S#2501-0037 -
Fwd/Rev ok when the accel pedal is pressed very slowly. When pressing normaly it pops out of drive. any ideas or thoughts.
  • Posted 30 Mar 2012 01:27
  • By Prentice
Prentice; Test the accelerator pedal transmitter under normal and slow operational conditions by a disconnecting the L25 plug from it's socket and apply 10v to the plug's 1 and 3 pins. Look for the pin numbers of the back side of the plug.
Voltage across connections 1 and 2 should read 4.5V dc with the pedal in neutral position. With the pedal actuated the voltage across 1 and 2 pins should be 4.5v to 10v. Rising and falling uniformly and if not within specification replace the transmitter.
  • Posted 30 Mar 2012 11:48
  • By MEngr
  • Missouri, United States
Is it an electrical or mechanical issue? Does the drive motor continue to spin, but doesn't transfer power to the wheels or does the drive motor stop?
  • Posted 30 Mar 2012 11:20
  • By bbforks
Muncie, IN, United States
