Alarm sounding
I have a RR5225-45.
My issue is the alarm is sounding and showing Control load on the display. I have went trough the wiring harness and checks in the manual but everything is checking out good. Also when I tilt the forks all the way up the alarm will go off and then it shows Monitor Disabled. Also everything is operating as it should. Truck is not down at all.
  • Posted 20 Feb 2016 05:59
  • Modified 20 Feb 2016 06:00 by poster
  • By Brad1110867
  • joined 3 Nov'15 - 15 messages
Popeye I have a crown that was getting stuck in air, turned out to be a joystick wasnt working replaced joystick now have code 367 (low battery) access 3 control module is blinking service indicator any ideas
  • Posted 23 May 2016 21:41
  • By road_dave
  • joined 23 May'16 - 2 messages
Popeye i have another ? for you. I am working on a Raymond Model 537.
The steering tire is jumping back and forth. I have install a new steer pot but this has not helped the problem. It will code 99. Which is a steer ref code. I have checked my steering encoder and everything seems to be doing what it is supposed to. any help would be a great help. Thanks Brad
  • Posted 1 Mar 2016 03:35
  • By Brad1110867
That took care of that problem thank you.
  • Posted 1 Mar 2016 03:29
  • By Brad1110867
Thanks, Popeye. I will check this out and let you know the out come.
  • Posted 22 Feb 2016 23:42
  • By Brad1110867
You either have the pressure switch or pressure transducer screwed into back left side of tilt cylinder beside the hoses that looks at hydraulic pressure to see how much weight you have on the forks so yours thinks it is overloaded. When you tilt all the way up or down the switch box bolted right above it turns it off because pressure reading will be high and unreliable so it does not monitor the weight.
  • Posted 21 Feb 2016 23:58
  • By popeye
Terberg YT222
Taylor TE650S
Terberg YT222
Taylor TE650S
Zhejiang UN Forklift Co., Ltd
