Aisin LP Hard to start/flooding
Yale GLC040 with a Aisin closed loop regulator. Truck had classic symptoms of a bad regulator. Regulator was replaced with new using Yale part number. New regulator had a different tag number and was slightly different with the addition of an adjustment screw on the top. Upon installation, the injector hose was found to be full of tar and the injector stuck open. Injector was cleaned with alcohol and seemed to close. Truck ran considerably better but had flooding issues when starting. A new injector was installed with the same problem. Coolant level is correct.
What does the adjustment screw on the new regulator do? I can find no technical manuals on the Aisin regulators. The screw was was 4.25 turns out from the factory, it was reduced to one turn out and seemed to make improvement but still floods to the point of smelling propane.
Current situation is the truck will start as it should when cold and runs well. With an immediate shutdown and restart it typically starts fine but if its left off for a minute two it is back to the flooding problem.
  • Posted 27 Mar 2025 22:06
  • By josh_gernentz
  • joined 26 Jan'21 - 5 messages
Yes Mazda engine, 2.0L I believe a F2?
My machine has 2 vacuum switches that vent to atmosphere at cylinders 3/4. Both are clean.
Turned the regulator 3 turns out, no difference in flooding.
  • Posted 31 Mar 2025 21:29
  • Modified 31 Mar 2025 21:30 by poster
  • By josh_gernentz
Depending upon age, motor. They used a vacuum valve towards 3&4 cylinder This fills up with tar as well and won't run well either. Can be cleaned out with brake cleaner. Has like 1/4 vac line in and out of it.
Turn the vaporizer top screw closed then start out at 3 turns. Should be close. Mazda motor? Psi motor?
  • Posted 29 Mar 2025 05:34
  • By ron_k
  • joined 2 Apr'15 - 139 messages
  • North Dakota, United States
That would be the mixture across all RPM ranges? The carb/mixer has one as well but I believe that is just for idle CO?
I have adjusted the regulator screw in which should be leaning it out...not adding excess to flood?
I can check can check for most emissions gasses, but have always been under the impression to set.4-.7% CO and send it
  • Posted 28 Mar 2025 21:32
  • By josh_gernentz
The screw on top of the regulator? Is for adjusting mixture. Should have some sort of emission analyzer to set or laptop for correct O2 sensor readings. In is to lean out. Out is more fuel.
  • Posted 28 Mar 2025 08:57
  • By ron_k
4kliftman
May 20-21, 2026 - Melbourne, Australia
August 19-21, 2026 - Bangkok Thailand, Thailand
edition #1277 - 16 April 2026
In this week’s Forkliftaction News , we look at how automation continues to be an area of rapid advancement for the materials handling sector, as we saw at LogiMAT 2026, but not everyone is convinced of its value - yet... Continue reading
Justin Byma Justin Byma
VP global product manager and strategy , Hyster-Yale Materials Handling
Chief operating officer, TVH Americas
Chief financial officer and treasurer, Universal Logistics Holdings
Director of aftermarket, Noblelift North America
Logistics Managers' Index jumps in March Fort Collins, CO, United States
