A/c question
How much r134 goes into the system ?????
  • Posted 21 May 2019 06:30
  • By POWERSHOP1804
  • joined 16 May'19 - 17 messages
  • New Jersey, United States
Thanks for your help
  • Posted 21 May 2019 23:45
  • By POWERSHOP1804
good deal, yes adding refrigerant to top off the system can get you by for a while i guess. As long as it is working but remember, if it has a leak that will slowly go away and the efficency will fall off again.
if it does you will have to find out where the leak is by doing the evacuation and vacuum the system to verify if a leak is there.
If you can get hold of a good gas sniffer you can use that to detect where the leak is while the system is charged up, if a leak is there the sniffer will find it.
  • Posted 21 May 2019 23:38
I didn't have the right amount of refrigerant but that works it's like a meat locker in there now
  • Posted 21 May 2019 23:26
  • By POWERSHOP1804
powershop1804,
if it is cooling but just not enough it could be it has a leak and some of the refrigerant has just leaked out and it's lost it's ability to cool.
Normally in a case like this the system would be evacuated and refilled to insure you get the correct amount in it, over filling the system can cause problems that may damage the compressor.
So i would evacuate it, pull a vacuum and see if it has any leaks.
Then recharge it to the correct amount suggested by the manual you have for the truck based on its serial number.
That information i gave in the previous post was for the first serial number shown in the list from hypass, it may not be correct for your unit.
what is the serial number from your lift? i can check that and verify what it says for refrigerant capacity.
  • Posted 21 May 2019 22:55
I looked in the manual it said 25 grams someone must have power washed the sticker off I can't find it I will try the 45.8oz it runs a little cool but definitely not cold thanks
  • Posted 21 May 2019 18:37
  • By POWERSHOP1804
there should be a tag somewhere on the system telling you how many ounces it takes. check on the compressor.
i did check one manual and it calls for 1300 grams (45.8oz) of r134a.
it all depends on the system and serial number and year of the truck.
  • Posted 21 May 2019 13:10
  • Modified 21 May 2019 13:12 by poster
edition #1280 - 7 May 2026
In this week’s Forkliftaction News , it’s financial reporting season with Hyster-Yale, KION Group and Konecranes all reporting revenue falls for Q1, yet maintaining their forecasts for moderate growth and stable sales volumes for the year... Continue reading
Ryan Pyle Ryan Pyle
Chief of staff, Logistics UK
Regional sales manager, Eneroc USA
US material handling & intralogistics industry manager, Beckhoff Automation USA
