I have a Toyota 5FG30 dual fuel truck with an Aisan LP regulator. If the truck sits for 3 to 4 hours it is extremely hard starting, however once it has been started it starts right up after that.
I know that the Aisin regulators were not the best. We used to replace them with adjustable Beam 60 regulators but they are now only availabe as non adjustable.
I have 2 questions, 1. -what is causing it to start hard and
2- can I change the regulator to another brand, like Impco, that would be compatible with the existing dual fuel carb?
take off that garbage install imco system approx about 350 canadian 4y never runs better
Dave,
Great tip on the screwdriver next to the solenoid to tell if it is energized.
Steve
Check that the Lage solenoid on the Aisin reg is energising, it only operates when the distributor is turning, it's a safety fuel cut off to shut down the LPG if the engine stalls. Crank the engine and hold a screwdriver close to the solenoid armature, it shoud "grab" the screwdriver. If the solenoid is not operating the fault is in the engine speed sensor or it's relay or in the distributor ignition module. However the most comon fault I find with the Aisin reg is the valve in the primary chamber stuck with tar, this gives all sorts of strange starting problems. Because the valve when it sticks is wide open it over gasses the engine and it somtimes wont fire up. If you remove the "gas" hose from the dual fuel carb and hold it about 2 inches away from the carb connector then try and start it, it will quite likely fire up because the mixture which was over rich is now weakened. If this gets it going, you will have to strip the reg and free up the primary chamber valve........thats the chamber nearest the large solenoid...........Safety warning don't smoke and make sure you are in a fairley open area or you may get a nasty little shock! good luck Dave
I would try draining the oil out the regualtor if you haven't already. These regulators can build up a ton of oil. I have not converted them over before so I am not sure how that would work. I know that rebuilding the Aisan regulator is not that bad of a job. The parts are expensive, in my opinion.
Roger
i had similar problem with a toyota lpg truck. found fault in distributor sometimes when it was turned off and tryed to restart it refused to fire. some days it could be on and off all day and not fail once. next day it woundn,t fire again. new distributor cured.check contacts in the cap for burning
