522740-5 Coding out
Been working on this unit for awhile. Replaced alternator, tmap sensor, crank sensor, both O2 sensors and still getting the above code. Unit cranks but shuts right back off as if out of gas and idles rough. Any suggestions on trouble shooting this unit?
  • Posted 9 Aug 2019 05:46
  • Modified 9 Aug 2019 05:59 by poster
  • By Teff114Ardent
  • joined 9 Aug'19 - 2 messages
It indicates the circuit is open. Check the wiring to the ECU from the O2 sensor.
1. Ensure truck power is OFF.
2. Change DMM to ohms scale. Verify DMM zero reading.
3. Disconnect the oxygen (O2) sensor connector, the indicated PDM connector, and the indicated ECU
connector.
4. At the sensor harness connector, measure the resistance on the sensor supply wire between the sensor
connector and the PDM connector.
Is resistance less than 0.5 ohms?
YES: Go to Step 5.
NO: The supply wire has an open circuit. Locate and repair/replace open wire/connection. Refer to
appropriate Wire Harness Repair manual, depending on lift truck model.
5. Measure the resistance of the sensor drive wire between the sensor connector and the ECU connector.
YES: Go to CAUSE B.
NO: The supply wire has an open circuit. Locate and repair/replace open wire/connection. Check that
counterweight has not crushed wire harness, if counterweight was removed. Refer to appropriate Wire
Diagnostic Trouble Codes Electrical System
Check
  • Posted 9 Aug 2019 22:25
  • Modified 9 Aug 2019 23:59 by poster
  • By BREWSKI
BREWSKI
Yes sir. Thanks I know what the codes means just trying to figure out any other diagnostics to perform as we have already replaced the O2 sensors.
  • Posted 9 Aug 2019 21:20
  • By Teff114Ardent
522740-5 Pre-Cat Bank 2 Heater is Open Circuit..
  • Posted 9 Aug 2019 07:18
  • By BREWSKI
Lift Technologies Inc.
UN Forklift FBT18NQZ1
UN Forklift FB25N1QZ1
Sue Tomic Sue Tomic
