36 volt charger keeps blowing fuses!!!!!
The charger keeps blowing fuses both with the 20 amp that came with it as well as a 30 amp as a trial. Not sure what is wrong. Any ideas?
  • Posted 3 Feb 2012 01:37
  • By zack_b
  • joined 3 Feb'12 - 1 message
Assuming that it is set for the correct input voltage, the #1 reason for immediately blowing AC fuses is that one or more of the transformers is shorted. They can not be tested or repaired.
  • Posted 3 Feb 2012 22:44
  • By duodeluxe
  • United States
duodeluxe
To start with:
1. Was the charger voltage settings properly set to the house input voltage & phase (single or three)?
2. Was the charger wired in correctly?
3. Or did this just start happening?
4. The charger make & model # would be go info to post.
  • Posted 3 Feb 2012 06:27
  • Modified 3 Feb 2012 06:29 by poster
  • By johnr_j
"Have An Exceptional Day!"
If the fuse is taken out straight away upon powering up via the mains, the most likely areas to look at will be either rectifier or transformer for short circuits.
  • Posted 3 Feb 2012 06:09
  • By JBrad
  • joined 3 Feb'09 - 14 messages
  • Lancs, United Kingdom
Deborah Baker Deborah Baker
