3 flash fault code
ST3000-20
5A504078
Flashing 3 code
Control contact pulls in an drops out
Put a working controller from another unit in but still has 3 light code
  • Posted 6 Jun 2020 01:51
  • By owen_r
  • joined 19 Jul'12 - 12 messages
  • Kentucky, United States
O
After you get the 3 digit codes count figured out Here is a troubleshooting guide.
Hope this helps
http://www.earpdistribution.com/trans/drivers/Documents/Crown%20Troubleshoot.pdf
  • Posted 9 Jun 2020 06:51
  • By Alvino_Revilla
  • joined 2 Jun'20 - 15 messages
What kind of controller is it? Sometimes codes are controller specific, rather than unit make specific.. Common crown codes are in hundreds. so the 3 flashes may be different numbers. Unless you are getting solely a "3"
  • Posted 9 Jun 2020 06:27
  • By Alvino_Revilla
Mitsubishi Logisnext FD25T5M
Unicarriers FD80-2
Lift Tek Elecar
Unicarriers FD80-2
Lift Tek Elecar
