2FG10 1971 CLUTCH REPLACEMENT
Hello to the forum
My clutch failed and i am trying to find a way to remove the cover assembly and the clutch disc.
I have been told that there is a safety pin to remove do gearbox shaft can withdraw and leave room to remove the cover assembly and disc.
However I can't find any pin. Any help would be highly appreciated.
https://youtube.com/shorts/dVzqClzi4_c?feature=share
  • Posted 4 Jul 2022 22:44
  • Modified 4 Jul 2022 22:48 by poster
  • By Rainfallgr
  • joined 1 Jul'11 - 12 messages
  • kilkis, Greece
Very glad I found this thread. Thank you for the part numbers. We have a 2FG10 that has needed a clutch for years and we finally have some downtime to fix it. Do you have any lifting information for the 2FG10? I don't have a certification plate anywhere on mine so I'm not even sure what it's lifting restrictions are.
  • Posted 3 Apr 2024 11:24
  • By Corey_Marks
  • joined 3 Apr'24 - 1 message
  • British Columbia, Canada
Clutch disc: 31260-20130-71, Aisin DW-001V
Clutch cover: 31210-10111-7 Aisin CW-009
Bearing : 9036345079 Aisin BT-027
Clutch dimensions outside 225mm inside 160mm 21 teeth
Bearing dimensions: outs. Diameter 73.8mm , inside Diameter 45mm thickness 16mm
  • Posted 15 Jul 2022 05:51
  • By Rainfallgr
  • kilkis, Greece
It doesn't have thread when parts arrive i will post back parts numbers and dimensions. It might help someone in the future
  • Posted 6 Jul 2022 16:28
  • By Rainfallgr
  • kilkis, Greece
The first hole you see in your video, (there are 3 holes) it should have threat inside it.
If you can assemble without pressure, thats fine, but mostly diffelcult to put it all thogether
  • Posted 6 Jul 2022 16:24
  • By John50
  • joined 7 Sep'19 - 153 messages
  • Netherlands
To be honest i just removed the clutch cover.
I have seen other video where people are installing 3 bolts to the clutch cover for installation of the clutch and then removing them.
My clutch cover do not have any threaded Holes. So how can I put pressure on the clutch prior to the installation?
Here's a video of clutch cover
https://youtube.com/shorts/mxT9y7buk2s?feature=share
  • Posted 6 Jul 2022 16:06
  • By Rainfallgr
  • kilkis, Greece
Just put pressure on the new clutch and mount the 3 bolts, then re assemble, don,t forget to take out bolts.
  • Posted 5 Jul 2022 23:11
  • By John50
  • Netherlands
100% success
https://youtube.com/shorts/yYWH7rCkLEA?feature=share
Is there anything that I should be careful when assembling back the clutch?
  • Posted 5 Jul 2022 23:04
  • By Rainfallgr
  • kilkis, Greece
Thank you John for your reply, i will check tomorrow morning and post back?!
  • Posted 5 Jul 2022 06:15
  • By Rainfallgr
  • kilkis, Greece
First put pressure on the clutch and place 3 bolds in it.
Put forks up and look from the front side of truck to the gearbox, in line with the gearbox there is a bold, take that one out and you see the pin.
You can pull it back to releave the clutch, there should be room to take it out.
  • Posted 5 Jul 2022 05:04
  • By John50
  • Netherlands
  • Posted 4 Jul 2022 22:48
  • Modified 4 Jul 2022 22:49 by poster
  • By Rainfallgr
  • kilkis, Greece
Lift Technologies Inc.
