Toyota 7FBESF15:
2004 toyota 2.2l propane diagnostics
I started with a check engine light on and couldn't find the pins to bridge for a code read out. I tried some combinations and turned on the SAS light, now I can clear the check engine light by battery disconnect for 10 sec.s but SAS won't go out, anyone know a trick to turn it off?
Anyone know the pins to bridge for check engine? I have E1, B+, FP, and one other but no Te1 or Te2 or W all listed as engine code in the early pin out.
  • Posted 15 Mar 2015 05:34
  • Discussion started by gazman
  • British Columbia, Canada
Gary
My boss assured me he found a site (no longer there) which told him which 2 wires to bridge in order to read a code flashed by the check engine light. Since the lift is over 10 years old and well past dealer service time I'd hoped an insider would still know how to do that while not giving away copyrighted info. I will try to update my profile so you could contact me if you feel you can point me in a direction.
  • Posted 27 Mar 2015 03:19
  • Reply by gazman
Gary
Gary, while I don't have any information I can easily share with you via e-mail, if someone did, which is frowned upon by most manufacturers and their reps (and these are fairly "non-trivial" instructions, to in-depth to relate here), they would need you to either have you add your e-mail to the profile (not in the forum posts, the software here correctly removes any properly formed url or e-mail address to lessen the "spam/spear phishing harvesting" that happens in online forums) or have you contact them by e-mail.
  • Posted 26 Mar 2015 11:16
  • Reply by edward_t
Hi again Edward, hope you are still out there, thanks for trying to help so far. I've got the final goods on this vehicle Model 7FGUC20; serial #86167: Engine designation 4TIEBO2.204Y ; TWC, O2S, TBI, NA Definitely a throttle cable. Now how do I get rid of the SAS light and read engine codes with a piece of wire?
  • Posted 26 Mar 2015 06:26
  • Reply by gazman
Gary
Got the Model 7fguc20 and i'm 90% sure it's throttle by wire. I didn't notice anything that looked like an electronic T-body
  • Posted 17 Mar 2015 05:12
  • Reply by gazman
Gary
no such luck (that forklifts would use some older form of self diagnostics common to most in the same year range) heck there are same model size and year ranges that don't use the same diagnostics. and any thing built before about 2002 will be "old-school" diagnostics anyway.
I see where you put "2.2L propane diagnostics". but I did not know which of the 2 different designations was the correct one. ;-)
We (in the forklift repair business) more often use the motor designation (4y), but since these machines sometimes get "rigged" with non-oem parts and sort of redesigned it is often better to give as correct much information as possible, so to not have it confused with other possible configurations. We also use the model and serial numbers since these machines may be manufactured and sold in differing years, and which year of manufacture/design would be designated by the model and serial number.
all that said, in 2004, I am pretty sure there were 2 different options for emission/carburation controls on LPG powered 4y motors that Toyota used, one was called ECS (a drive by wire-electronic throttle body) and TWC (three way catalytic converter with a throttle cable connection to the carburator). these use differing systems and different places to jumper to read out "flashing light codes". let us know which one you have and then we can go from there.
  • Posted 16 Mar 2015 06:18
  • Modified 16 Mar 2015 06:19 by poster
  • Reply by edward_t
I'm sorry, I'm new to this. I did put 2.2 liter propane 2004 Toyota forklift in the header but apparently that doesn't show up, I'm pretty sure it is series 7 but the rest of the model I won't know until I go back in to work later in the week. I hoped that forklifts would use some older form of self diagnostics common to most in the same year range. The connector block is similar to a pre "94 car
  • Posted 16 Mar 2015 04:40
  • Reply by gazman
Gary
I am pretty sure we will need the correct model and serial number, as well as what motor and emmission control options you have. the truck you listed "7FBESF15" I am fairly sure is a battery electric.
  • Posted 15 Mar 2015 05:51
  • Reply by edward_t
UN Forklift FBRS15KQZ2
Taylor TX175
New - Sale & Hire
edition #1228 - 1 May 2025
Linda Häkkilä Linda Häkkilä
Louisville, KY, United States
Dubuque, IA, United States
Toyota 4FD240
Ncn 110TH
Ncn 110TH 2023
VETTER Forks, Inc.
