2001 7000lb yale v6 no powersteering
I purchased this forklift at a auction and everything starts and runs good all hydraulics work great it just does not have any power steering. Is the power steering on its on pump or does it come from the hydraulic pump that runs the rest of the system? any ideas on what to look at?
  • Posted 1 Dec 2013 01:47
  • By fabandy
  • joined 1 Dec'13 - 12 messages
  • Kansas, United States
I was thinking these trucks had a belt driven dedicated steer pump. But i could be wrong. I did some work on one a few years back that had a bolt on as i described but it could have been like a 5 ton model. A real **** to change out best i can remember.
  • Posted 3 Dec 2013 14:57
  • By RCAV8TOR
  • Alabama, United States
I am sorry I do not have serial numbers right now as it is still in the warehouse I purchased it from we will be bringing here next week just wanted to see if there was anything that is notorious on those for the steering. Thanks for all your help guys I appreciate it.
  • Posted 3 Dec 2013 02:41
  • By fabandy
a serial number would help somewhat
but as steering systems go you'll need to check the pressure with a guage at the auxillary section of the control valve. This is where it gets it's oil from.
Sure the priority valve might be sticking but isolating the problem should be your main priority, the only way your going to achieve this is to check pressures at specific points-.
- control valve auxillary output
- orbital valve pressure out ports
- at the steering cylinder (pulling each line and checking for bypass flow)
You can start at the control valve then follow the circuit till you locate the pressure loss.
Steering pressure should be about 1400psi at the test port on the control valve. (since we have no serial number this is just an educated guess based on that class of truck)
you can also pull the priority valve out and take it apart and clean it... since the truck was sitting for an extended period of time it may just be stuck.
  • Posted 3 Dec 2013 02:28
  • Modified 3 Dec 2013 02:29 by poster
I did look for a ps pump and did not see one so I will check the priority valve next and see. I am pretty sure that the steering was working on it when it was parked 7 months ago. Is there a check valve anywhere that may be stuck just dumping the pressure back in to the tank?
  • Posted 3 Dec 2013 02:24
  • By fabandy
Like BB says. The orbitrol beneath the steering hand wheel will probably have 4 lines. One each to both sides of steer cylinder , one low pressure hose the ends up dumping back to tank and then the pressure line you are looking for. It will either go to the main hydraulic valve, a priority valve or the pump (it could have a dedicated ps pump).
  • Posted 3 Dec 2013 00:54
  • By Forkliftt
  • Louisiana, United States
Steve
steve at forkliftt dot com
I've never worked on your exact model, but I have had steering issues on smaller Yales & if it steers at all (with no power assist) it's been a problem in the hydraulic control valve. On smaller Yales the power assist comes from the control valve-I'd trace the hosing to see if yours is set up the same way.
  • Posted 3 Dec 2013 00:40
  • By bbforks
I felt like popeye after I got done moving it but it does turn just not with power. That was with weight on it.
  • Posted 3 Dec 2013 00:18
  • By fabandy
If there's weight on the steer axle, can you muscle the steering wheel to turn the wheels, or is there no reaction at all with weight? I'm thinking maybe the steer cyl needs service.
  • Posted 2 Dec 2013 23:23
  • Modified 2 Dec 2013 23:23 by poster
  • By bbforks
could the priority valve be stuck not allowing fluid to go to the orbital.
  • Posted 2 Dec 2013 23:18
  • By fabandy
the steering works just no power.
  • Posted 2 Dec 2013 23:17
  • By fabandy
if you lift the back of the counter weight off the ground and the engine off, can you steer the wheels from left to right?
  • Posted 2 Dec 2013 08:23
  • By Howitt
  • joined 13 Feb'09 - 80 messages
A model and SN would help. Locate the main hydraulic pump. It's going to have a large suction hose from the tank attached to it and at least one smaller hose leaving it going to to the main hydraulic valve OR a flow divider/ priority valve. If there are three lines at the pump, the smallest probably feeds the steering orbitrol valve, and the pump would have a priority valve inside of it.
  • Posted 1 Dec 2013 14:47
  • By Forkliftt
Steve
Taylor TX175
New - Sale & Hire
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
