12546 Code intermittent with battery charged
Hyster E50XN giving code 12546 even with battery charged, and even after code goes away it comes back. Sometimes these forklifts "remember" the code even after charge, but that's not what's happening this time. We can unplug the battery, plug it back in, rekey and the code goes away and the machine can be operated. But if you immediately rekey a second time the code is back.
Could something be wrong with the seat or battery connection? Every time the hood was up, turning the key on, it was fine, but after lowering the hood and turning on the key, the code comes back, with or without someone actually sitting in the seat. Also, with the hood up, you can put pressure on the seat sensor and turn the key on and the same fault comes up.
  • Posted 6 Sep 2023 23:48
  • By Andrew_Guild
  • joined 2 Sep'21 - 9 messages
Andrew Guild
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
Phytoplankton create at least half of the world's oxygen production, despite amounting to only about 1% of the global plant biomass. They also respond rapidly on a global scale to climate and environmental variations, so are often used as indicators of marine health.
October 13-15, 2026 - Shenzhen City, China
November 10-11, 2026 - Auckland, New Zealand
June 17, 2027 - Nottinghamshire, United Kingdom
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
