Toyota 2FBE18:
11741NO FWD
You can hear the controller and contactor click in fwd, but whines when you press on the accelerator, rev works fine, I think it may be the contactor, wondering if any one has any ideas.
  • Posted 12 Jan 2010 01:49
  • Discussion started by Barfly_olaf
  • Nova Scotia, Canada
SEMPER FIDELIS
Hi thanks for the reply, I thought that it might be one of those, but I think the problem is in the steer control card. I f you unplug the card then the drive seems to work fine. I talked to the local toyota guys and they never heard of this problem. The problem with these machines was they were so reliable, no one knows how to fix them. Thanks Brent
  • Posted 14 Apr 2012 05:28
  • Reply by debra_j
  • British Columbia, Canada
It is an open DF diode. There is an upgrade diode kit available from Toyota
  • Posted 12 Apr 2012 13:42
  • Reply by charlie_j
Take time to do the job right the first time, or you will have to make time to do the job over
I was wondering if you got this problem solved, I have exactly the same problem.
any help would be great, thanks Brent
  • Posted 13 Jan 2012 08:51
  • Reply by debra_j
  • Posted 13 Jan 2010 13:49
  • Modified 18 Jan 2010 03:58 by poster
  • Reply by rick_c
technology: (no user serviceable parts inside)
It sounds like it is struggling in fwd as if low volts to motor, but rev makes that typical whine as you press on the accelerator on these toyotas. Low pitch to high pitch the faster you go. wheels turn very slowly in forward when drives are raised. You can hear the contactors open and closing as you turn the wheel.
  • Posted 13 Jan 2010 00:22
  • Reply by Barfly_olaf
SEMPER FIDELIS
  • Posted 12 Jan 2010 13:27
  • Modified 18 Jan 2010 03:57 by poster
  • Reply by rick_c
can you further define the "whine", and compare the whine to any noises you hear in rev.?
  • Posted 12 Jan 2010 05:49
  • Reply by edward_t
edition #1228 - 1 May 2025
