1.25XL hyster Forklift won't go back or forward
We have a 1992 year 3 wheel electric 1.25XL hyster Forklift
Worked perfectly well until this morning, not moving forward or backward, everything else works fine, tilt, lift, steering etc
What are the things we need to try and trace the fault
Did the simple things like seat switch, more than that we're lost
  • Posted 23 Dec 2022 07:31
  • By Andrew_Forrest
  • joined 23 Dec'22 - 1 message
  • United Kingdom
Hi Scott it's a 3 wheel truck so will be an A range with a sevcon controller
  • Posted 24 Dec 2022 07:00
  • By lifter01
  • joined 4 Jul'09 - 463 messages
Model and serial number please I'm guessing it's an A1.25XL so will have a sevcon controller in the rear of the truck. Is it monotrolor colum change?? It could be a faulty brake switch, a wiring fault to either the brake swtich, monotrolor pedal/direction control switch or throttle pot, a faulty throttle pot or a blown SCR (I've changed a few), you'd be better pitting the bullet and getting an engineer in to look at it
  • Posted 24 Dec 2022 06:59
  • By lifter01
Do you know what system the truck has installed in it if it is ev100 or general electric with two gray boxes you will need a hand set to check codes am sure you check all fuses to drive controller.
  • Posted 24 Dec 2022 06:22
  • By Scott_
Scott
Sue Tomic Sue Tomic
Noblelift
