The TCM PRO Four Wheel Electric Lift Trucks
- 31 Jan 2008 ( #345 )
The TCM PRO-CB Class 1 four wheel electric lift trucks are clean sheet designs engineered to increase your operation's productivity and profitability. In capacities ranging from 3,000 to 6,000 lbs, they deliver reliable day-to-day performance, improved safety, easy operation in restricted spaces, and reduced maintenance. Their state-of-the-art features include:
  • Move more material quicker and with greater control. The TCM PRO drive and lift motors are 100% AC powered. They deliver very high torque at low speeds for smooth starting and creeping, and also give higher travel and lifting speeds. TCM PRO's outside turning radius has been decreased significantly, allowing these trucks to easily maneuver in tight spots so you can maximize your floor space utilization.
  • Add valuable hours to your material handling day. TCM PRO electric lift trucks give you a full eight hours of run time on one charge. Their AC motors have superior operating efficiency and the inverter control system instantaneously manages operating current draw and power regeneration. As an added benefit, you may need fewer batteries to run your operation.
  • Put reliable high technology in your fleet. The TCM solid-state controller is designed to be reliable itself, and also has Automatic Drive Monitoring to protect the powertrain during operation. The controller is adjustable for 3 speed and power settings: Economy Mode, Power Mode, and Super Mode so you can tailor your power requirements to the application.
  • Reduce your cost of operation with simplified maintenance. TCM PRO-CB Series instrument panels carry on-board self diagnostics to simplify troubleshooting and maintenance at the job location. You do not need a separate hand-held instrument for most testing procedures. The 100% AC motors have no motor brushes or contactors to wear out, which reduces maintenance to a minimum.
  • The largest brakes in the industry. Our automotive-type brakes are the largest in the industry, have superior stopping power, are easily maintained, and will not overheat even in high cycle operations.
  • Improve your Operators' productivity and comfort. Access to the operator position is improved with wider steps and a 33% wider floor. The small diameter, anti-kickback steering wheel is mounted on a tilting steering column for comfort and easy access. The adjustable seat has an integrated restraint system to protect the operator, and the smooth controls give precise handling and load control. The TCM wide view mast and the lowered instrument panel give the operator an unrestricted view of the fork tips during load engagement.
  • Improve your Operators' safety. A complete safety system of interlocks is standard on these trucks, including safety neutral switch, weight sensing seat interlock, and short circuit lockout. The TCM PRO-CB Series also has tilt cylinder lock, travel speed presets, and standard anti-roll back for safe starting up ramps. TCM overhead guards provide outstanding visibility, safety-rated protection, and high mounting for headlights, brake lights, and turn signals.
  • Add even more productivity and safety. Order popular options including TCM's integrated side shifter for even more lifting capacity. Add finger tip controls for fast and fatigue-free all-day operation. Auto power-off is available to extend run times. Lift Lock improves safety by gradually lowering the forks in the event of line pressure loss.
  • Performance, TCM PRO-CB Series.
    • Load Capacities - 3,000 to 6,000 lbs.
    • Free Lift - 4.1 in to 4.5 in
    • Battery Power @ 36V/AH/6HRS - 36/800 to 36/1250 varies by model
    • Battery Power @ 48V/AH/6HRS - 48/770 to 48/1100 varies by model
    • Overall Length - 118.3 in to 129.9 in varies by model
    • Overall Width - 37.8 in to 43.5 in varies by model
    • Overall Height Forks Lowered - 85 in
    • Website. More details are available at www.tcmusa.com.
Since 1949, reliable, high performance TCM forklift trucks have been used in demanding industrial applications throughout the world. TCM trucks are built in South Carolina. Product lines include Class 1, 4, and 5 lift trucks in capacities ranging from 3,000 lbs to 22,000 lbs, pallet jacks, and OEM and aftermarket replacement parts and accessories.
Click here to visit the TCM ShopFront
