Ruyi Electric High Lever Order Picker
- 5 Apr 2012 ( #559 )
RUYI's new Electric High Lever Order Picker with lots of advantages.
  • Low centre of gravity ensures good stability.
  • Advanced electric steering technology (EPS) with ergonomic design, automatic reset, height display and automatic deceleration on high lifting.
  • Fingertip control via joystick, stepless speed control for driving, adjustable lifting and lowering speed.
  • Buffer oil cylinder: the oil cylinder will automatically decelerate when raised 500mm off the ground to prevent impact and reduce noise.
  • The mast and the frame are dividable and exchangeable.
  • Low battery protection setting prolongs the battery use time.
  • AC motor eliminates replacement of the carbon brush, provides good ramp starting performance and regenerative braking functions.
  • Sideway battery is convenient for exchanging and maintaining.
  • The mast material is a special type imported from Germany.
  • The truck can automatically decelerate when turning quickly.
  • High performance multi-function instruments with LED light and display
    function. LED indicators include battery activity, fault indicator, Electric thermometer indicator, pedal indicator and handbrake indictor.
  • Multi-function display, include battery status, performance, working hour, accelerator, speed, wheel position and travel direction.
  • Press right and left keys to switch to different grades: high, normal, low and lowest.
Mr. Chu Jiang
Vice President
Tel: +86-571-87153626, 87153634
Fax: +86-571-87153628, 87153638
Email: ruyi@mail.hz.zj.cn, sales@liftool.com
Web: www.xilin.com
Or; Click to view the RUYI ShopFront
+86 574... Show
656 North Taoyuan Road
Ninghai, Zhejiang 315600
China
