Safety and efficiency - 2.5 Tone RUYI Electric Pallet Truck (CBD25T)
- 24 Feb 2011 ( #502 )
Advantages:
Safety and Stability
  • The truck is designed to be steady, with a broad body and wide forks. It features a smooth running, strong load capacity and excellent climbing ability, and the truck body and wheels are durable and reliable.
  • Side-standing operation and equipped with safety armrest for a good visibility and safe operation, while also avoiding operator fatigue.
  • Power steering system(EPS)makes steering operation easy, more flexible and safer.
  • Multi-function display: battery status, hour meter, fault code, slow running state, etc.
  • Safety armrest equipped with operating switch design allows control of lifting/lowering, slow running and the horn functions with either hand.
  • High-capacity Battery(300Ah)and high-power Drive Motor provides strong power and ensures lasting runtime.
  • The controlling system uses efficient micro computer MOS, drive motor is the AC adjustable-speed motor which provides long life and good speed adjusting performance, and is maintenance-free.
  • AC- motor eliminates carbon brushes and has good starting performance of the ramp.
  • The side door of battery is conveniently opened. Loosen the locking mechanism and it is very easy to pull the battery unit out from the side.
  • The handle is equipped with an emergency reverse direction switch, which provides safer operation.
  • Build-in pressure relief valve protects the truck from overloads, and increases the truck's reliability.
  • Braking applies with handle upright and horizontal position, increases the truck's safety.
  • Emergency power disconnector.
  • Turtle- shaped low speed switch.
  • Stepless speed control.
Structural
  • Standing drive motor system makes the replacement and maintenance of the driving wheels easy and convenient.
  • The truck is equipped with a load-backrest, which facilitates carrying of bulky goods.
  • The lifting height reaches 135mm, which provides better passing ability.
  • Combined balance wheels increase steadiness, preventing the truck from being rocked from side to side.
  • The balance wheel is detachable, and is convenient to maintain.
Easy maintenance
  • Low battery protection setting prolongs the battery use time.
  • CANbus technology reduces wiring complexity, making the line clear, orderly and easy to repair. And also increases the truck's reliability.
  • Hall-effect throttle control eliminates wear components and prolongs its use time.
  • With reasonable design, the cover is reliable and easy to dismantle, which makes the maintenance of the electrical parts very easy.
All enquiries are welcome, please contact Mr. Chu Jiang for further information:
Mr. Chu Jiang
Vice President
Tel: +86-571-87153626, 87153634
Fax: +86-571-87153628, 87153638
Email: ruyi@mail.hz.zj.cn, sales@liftool.com
Web: www.xilin.com
+86 574... Show
656 North Taoyuan Road
Ninghai, Zhejiang 315600
China
