JCB introduces its smallest Loadall
- 15 Oct 2009 ( #432 ) - Rocester, United Kingdom
JCB's newest Loadall telehandler is 1.8 metres high.
JCB has produced its smallest Loadall telehandler, the result of a design innovation that has reduced the machine height to less than two metres.
The 515-40 Miniscopic model is 1.8 metres (5.9 feet) high, 2.97 metres (9.74 feet) long and weighs less than 3.5 tonnes (7,716lbs). JCB spokesman Nigel Chell tells Forkliftaction.com News the machine's "excellent power to weight ratio", enables it to deliver a powerful performance despite its compact dimensions.
To achieve the low working height, JCB says it challenged conventional design concepts to develop a unique, off-set, single-spine chassis. The machine's cab occupies the resulting space.
The new model is targeted at building contractors, builders' merchants and plant hirers. It features four-wheel drive, four-wheel steering and a hydrostatic transmission. Powered by a 50hp Deutz engine, the JCB Loadall can handle a 1,500kg (3,307lb) payload at a four-metre (13.12 foot) lift height.
Chell says the JCB 520-40, the company's next smallest Loadall, is 1.97 metres (6.46 feet) high, 2.92 metres (9.58 feet) long, and weighs 4.4 tonnes (9,700lbs).
JLG releases electric telehandler, expands range
JLG releases electric telehandler, expands range 19 Jun 2025 - McConnellsburg, PA, United States - 1 min read
New Holland releasing new telehandler in North America
New Holland releasing new telehandler in North America 13 Feb 2025 - Pennsylvania, United States - 1 min read
Lift Tek Elecar
