Flexible Container Handling
- 8 Oct 2009 ( #431 )
Reachstackers from Cargotec combine performance, comfort and reliability.
In the environment where reachstackers work, there's simply no room for anything but perfection. The most extensively tried and tested reachstackers in the world are made by Cargotec. Thousands of machines in more than 160 countries have made us known for our renowned quality. In all kinds of areas we combine experience with innovation.
Our ambition with the Kalmar DRF reachstacker is clear: high performance throughout the operating cycle, high user-friendliness, and low running costs, together with a high level of environmental awareness. Any driver with the ability to take advantage of the machine's capacity and technical benefits will find the Kalmar reachstacker a powerful, flexible tool for handling containers with the lowest possible operating and maintenance costs.
Flexible handling solution
The Kalmar reachstacker set the trend for the whole reachstacker concept over two decades ago. Since then we have been the leading manufacturer when it comes to technology development and operational safety. Container handling with a reachstacker is one of the most flexible handling solutions whether to operate a smaller one-unit terminal or a medium sized port. A reachstacker can handle containers quickly and efficiently in narrow spaces, while still ensuring the driver has optimum visibility.
The extensive freedom allowed by the lifting equipment, boom and attachment, and its rotation possibilities, gives the driver can improve the work efficiency of the unit, by not needing to approach the container from a 90 degrees position.
Operational performance starts here
The cab in the Kalmar reachstacker is the world-renowned Spirit Delta driver environment. Based on extensive research, it provides an ergonomically designed workplace where the driver can do his job more quickly, safely and efficiently.
There is plenty of room with open floor space for more legroom. Visibility is excellent with everything positioned to allow optimum vision.
Few things are as beneficial as good ergonomics. The driver environment in the Spirit Delta takes advantage of the driver's full potential. A driver who can work an entire shift without pains in the head, back, neck and feet is quite simply a more efficient driver.
Models and options
Even the basic model of the Kalmar reachstacker is well-equipped. Separate hydraulic and brake systems, return filters, wheel nut protection, interval wipers, tinted windows, automatic gear shifting, electronic climate control and a lot more.
Moreover, there is an extensive list of options that enable you to adapt the machine more precisely to your situation.
The Kalmar reachstacker is available in a variety of models and wheelbases. This variety, mixed with our flexibility, makes it possible for us to offer the most optimized combination of wheelbase and capacity in second and third row. No matter what your material handling needs are, Cargotec can offer you the right solution.
Click here to view the Kalmar Shopfront
Get in touch with Cargotec Sweden AB
Cargotec Sweden AB
+46 372... Show
Cargotec Sweden AB
Torggatan 3, 340 10
Lidhult, Sweden
Cargotec Sweden AB
