EnerSys Reduces Energy Consumption
- 28 May 2009 ( #412 )
EnerSys Motive Power UK is working with lift truck users to increase their charging station efficiency, by incorporating high frequency (HF) chargers and fleet management systems in tailored solutions which reduce energy consumption and maximise truck up-time. The benefits are substantial. EnerSys believes that these systems will save money over the term of the contract.
The drive for greater energy efficiency has been boosted by the addition to the EnerSys range of Powertech IQ, a highly efficient HF smart charger which communicates wirelessly. EnerSys - the European leader in motive power batteries - has designed Powertech IQ to be fully programmable in order to reduce electricity costs through improved efficiency and a lower charging factor.
Powertech IQ HF chargers have a real-time clock which allows charging operations to be programmed exactly to take account of off-peak electricity tariffs. Equalisation charge can be started when convenient and real dates programmed for each event.
Wireless communication between the charger and battery is enabled by a WI-IQ wireless battery monitor fitted to the main DC cable of the battery. Information on charge, temperature and voltage can be uploaded wirelessly to a PC for data analysis.
A USB port is positioned on the front panel of the Powertech IQ charger for data upload and download. An Ethernet Port to provide remote diagnostics is available as an option to enable remote management of a charger fleet, and when connected to a network provide access to charging management on a global scale. Charge level is indicated by colour changing display panels and the charger menu can be fully programmed by the user.
Automatic charge optimisation is made by the charger according to the battery's temperature, capacity and technology. This occurs throughout the charge period to compensate for any current loss in the DC cables. The wide LCD display delivers real time information on the charging process and events. Five different coloured backlights indicate the different states of charge or function. The Powertech IQ charger will even interrupt the charge if excessive temperatures occur and charge will not commence if a defined percentage discharge is not reached.
EnerSys has engineered improved safety into Powertech IQ chargers by providing arc-less connection and disconnection. This new range of smart HF chargers combines all the existing features and benefits of HF technology as well as innovative new features and compact wall-mounted design to save floor space.
More information, visit : www.enersys-hawker.com
Local contact :
Karen Smith
Tel: +44 0161 727 3800
Fax: +44 0161 727 3899
email: karen.smith@uk.enersys.com
Click here to view the EnerSys Shopfront.
