Protect your largest warehouse investment, the Racking!
- 1 May 2008 ( #358 )
RackDeflektor won't stop a forklift, but will reduce the damage due to continuous collisions by pallets and forks hitting the uprights.
RackDeflektor NA08 booth was a great success! Even with a booth in the back of the hall on the last row, RackDeflektor saw over 400 visitors. This unique new product and its bright color made it visible and interesting to every visitor who had any racking!
When competing against steel and other manufacturers of Plastic products, RackDeflektor stands out!
  • RackDeflektor is priced competively with most steel guards.
  • Easier and faster to install than Steel! No tools required to install RackDeflektor!
  • Installation cost 10% of steel guards. RackDeflektors patented clip mount design gives a secure mount and makes inspections easy.
  • No concrete floor damage from impact. Saves $$$ in repairs
  • Mounts on any rack, including drive in rack!
  • Mounts at the most effective height for your operation!
Better than the other plastic brands!
  • Narrow design does not restrict entry in the lower pallet slots
  • Works on any size and brand of rack. Different clips are available to assure a secure fit.
  • If you change or move your rack, removal and replacement of RackDeflektor could not be easier! Replacement clips available at reasonable prices.
  • If shelf beams are in the way, simply trim the thin sleeve around the beam. It does not inhibit the effectiveness of RackDeflektor.
  • Does not require zip ties to secure to large rack.
RackDeflektor is available for immediate shipment from the Chicago, IL area warehouse.
Contact Nita at +1.630.590.3984
Sales@RackDeflektor.com
www.RackDeflektor.com
