In high-bay, ultra-narrow aisle warehouses where every inch of vertical space counts, the challenge lies in accessing deep pallet positions quickly and safely. The Xilin CQDH20C Double-Scissor Reach Truck meets this challenge head-on, transforming vertical storage operations with innovative design and proven performance from over 40 years of engineering excellence.
Advanced Double-Scissor Mechanism for Precision Handling
The core of the CQDH20C is its double-scissor reach mechanism, delivering 43 inches of horizontal extension for deep pallet access without truck repositioning. Combined with a full free-lift mast that enables vertical fork movement without increasing overall height, this system ensures optimal performance in low-ceiling or mezzanine environments
High-Performance Lifting & Robust Construction
Achieving lifting speeds up to three times faster than conventional forklifts, the CQDH20C's high-speed hydraulic system allows for rapid vertical movement, and its electro-hydraulic proportional controls deliver precise modulation of lift and lowering speeds, minimizing shock loads and ensuring stable handling of delicate items. The mast, constructed with German-sourced C-profile steel and Xilin’s reinforced design, provides exceptional rigidity and reliability at extended heights.
Smart Control & Operational Efficiency
Featuring EPS electric power steering, automatic operator-presence braking, and an intuitive multi-function joystick, the CQDH20C offers effortless operation. Its CANbus electrical system simplifies diagnostics and maintenance, while the brushless AC drive motor and 36V CURTIS controller ensure extended operation with minimal downtime.
Key Specifications
- Capacity: 3,500 lbs
- Max Lift Height: up to 453 in
- Battery Options: 36V/1000Ah lead-acid or 36V/700Ah lithium
Engineered for distribution centers, manufacturing warehouses, and facilities with narrow aisles and tall racks, the CQDH20C offers precise control, strong stability, and high operational efficiency.
For more information, contact us.
