LFP chemistry and the circular future of forklift power
David Woods -
Your Focus
- 10 Jul 2025 ( #1238 )
LiFePO4 batteries are an emerging forklift energy source
In this article, David Woods, product head of motive.li and general manager for South Africa at Maxwell+spark, examines how lithium iron phosphate (LFP) chemistry offers a safe, efficient, and circular energy solution for modern forklift fleets.
As the materials handling industry accelerates its transition to electrification, lithium-ion batteries have firmly established themselves as a proven and reliable alternative to traditional lead-acid systems.
Among the various lithium-ion chemistries available, lithium iron phosphate (LiFePO4 or LFP) has emerged as the preferred choice for many forklift applications, as it offers a unique combination of safety, operational efficiency, and alignment with circular economy goals.
What sets LFP apart?
LFP batteries utilise a lithium iron phosphate cathode and a graphite anode.
While this chemistry has a lower nominal voltage (3.2V per cell) and energy density compared to NMC (nickel manganese cobalt), it offers significant advantages that make it well suited to industrial vehicles such as counterbalance trucks, reach trucks, and pallet jacks.
- Inherent safety
LFP exhibits excellent thermal and chemical stability. It is far less prone to thermal runaway—a chain reaction that can lead to fire or explosion—than cobalt-based chemistries. This is particularly important in enclosed environments such as warehouses and cold stores. The chemistry’s robust structure allows it to withstand abuse conditions including overcharging, over-discharging, short circuit, and mechanical shock with minimal risk.
- Extended cycle life
With typical life cycles exceeding 4,000–6,000 full depth-of-discharge cycles, LFP batteries can last two to three times longer than lead-acid alternatives and significantly outlast NMC in most industrial use cases. This durability reduces the frequency of replacements, lowers maintenance costs, and improves fleet availability.
- Thermal and operational resilience
LFP maintains stable electrochemical performance across a broad temperature range. It tolerates high ambient conditions (up to -60°C) without degradation and can be integrated with heaters or thermal buffers for freezing environments. This makes it highly reliable in both harsh outdoor yards and refrigerated indoor zones.
- Fast charge and high discharge capability
LFP cells support high charge acceptance (typically 1C) and deliver sustained discharge currents without significant voltage sag. This enables opportunity charging and supports high-throughput operations where downtime must be minimised.
A chemistry aligned with circularity
Beyond performance, LFP offers important advantages from a lifecycle and sustainability standpoint—an area of growing concern for fleet operators and regulators alike.
Environmentally responsible composition:
LFP batteries are free from cobalt and nickel, reducing reliance on critical minerals linked to ethical and environmental concerns. Their chemical stability also simplifies end-of-life handling and reduces hazardous waste.
Second-life readiness:
Due to their long usable life and predictable degradation behaviour, LFP packs are ideal for second-life applications such as stationary energy storage or grid support—extending value beyond the forklift.
Modular construction:
Increasingly, industrial LFP batteries are designed with serviceability in mind. Modular architectures allow individual components to be replaced, extending battery life and reducing waste.
As battery regulations evolve globally — whether through emissions targets, extended producer responsibility, or mandatory recycling thresholds — operators and OEMs are under increasing pressure to choose solutions that deliver both operational and environmental value.
LFP stands out as a chemistry that not only meets the practical demands of industrial fleets, but also aligns with growing expectations around sustainability, safety, and lifecycle transparency.
For fleet managers worldwide, it offers a dependable pathway toward more resilient and responsible electrification.
Also Read:
How positive friction prevents forklift accidents before they happen
Stuart Taylor
3 minute read
How positive friction prevents forklift accidents before they happen Safety First - 27 Nov 2025 (#1258) Stuart Taylor is managing director of Mentor FLT Training Limited looks at ways positive friction can be used to help prevent forklift accidents from happening
How advanced relay contact design transforms forklift reliability
Carlos Mendes
3 minute read
How advanced relay contact design transforms forklift reliability Your Focus - 20 Nov 2025 (#1257) Carlos Mendes is a product manager for switching at Durakool, working closely with engineers and buyers to bridge the gap between application and specification.
Manual or automated material handling: finding the right balance
Diana Davoyan
3 minute read
Manual or automated material handling: finding the right balance Your Focus - 6 Nov 2025 (#1255) Diana Davoyan is a marketing professional and copywriter in the global robotics sector, with extensive experience in industrial and warehouse robotics. Here she looks at striking the right balance between manual and automated MH operations.
