Graphic and textual information of port machinery XPT75E Pure Electric Port Tractor
- 12 Oct 2023 ( #1149 )
Electric Series Port Tractor
Introduction:
XPT75E Pure Electric Port Tractor Adopt charging mode, offset fully suspension air-cab, rear sliding door for entry and exit, airbag seat, high comfort. Charging standard requirements are European standard dual gun charging. Its battery pack of BYD 289 kWh can be operated for a long time. Greatly improves the work efficiency. The cab is on the left side. It has air suspension four-point airbag damping function, and the field of view is wide and convenient for construction.
The model is pure electric and pollution-free, achieving green environmental protection. The components meet the automotive range level and have high reliability. It meets the environmental usage requirements of -40°C to 65°C.
Terminal tractor is suitable for low speed, short haul, heavy load, uninterrupted operation and other working conditions, used in terminals, logistics parks container transport, bulk cargo transport, ro-ro ship operations, but also can be used in steel mills, yards, airports, mines and other short distance, continuous operation of equipment and cargo traction transport operations.
Advantages of pure electric port tractor:
  • Heavy load;
  • Lower use and maintenance costs;
  • Pure electric, zero pollution, help green port construction;
  • Offset cab, wider vision, safer driving;
  • Heating and cooling air conditioning, driving more comfortable;
  • Superior wire control performance, support remote control and unmanned driving.
Good appearance:
  • Standard international mainstream, compact layout, round style, beautiful and practical;
  • The best shape size, small turning radius, superior performance, good comfort;
  • Streamlined design, harmonious aspect ratio, bumper shape, cab with milky white, frame body gray, black tires, white rims, in the port environment, with sky blue and sea blue echo, giving people a sense of security and comfort.
Vehicle layout:
