Reddot IE Series First Li-ion Forklift - Replacing IC truck
- 3 Aug 2023 ( #1139 )
REDDOT's IE (1.8ton / 2.5ton / 3ton / 3.5ton) Forklift is the most versatile truck you can find on the market. Due to the usage of Li-lon technology in combination with an onboard charger, plug it into any standard power outlet and the battery will be opportunity charged. No need for any external charging device. Just Plug & Play.
Adapt LFP Li-ion battery that prevents the battery from self-ignition and ensures safety operation.
The forklift is a very compact truck, the leg room has been increased for better ergnomics, for the flexible operation at few hours per day.
Compared to a diesel forklift truck, IE30 saves 30%-50% of energy costs with li-ion technology. And there is no maintenance fee with no air filter, oil filter, engine oil or starter battery installed on the truck.
Easy driving: The truck is equipped witha  mechanical braking system. The system shortens the braking distance to ensure safety while reducing the driving fatigue in the meantime.
Brilliant visibility: A wide view mast ensures good visibility during equipment operation. This enables operator to better monitor the status of the cargo.
Contact us to find out more!
REDDOT EQUIPMENT
www.reddotequipment.com
www.reddotcenter.com
