Damage to Pallets and Goods as Result of Incorrectly Sized Forks Scroll down for video
- 15 Jun 2023 ( #1132 )
Have a look at your warehouse or dock. Instead of looking at the inventory or your employees, focus on the walls and shelves. What do you see?
If you notice dents in pallets, holes in walls, or even damage to your goods that have the distinctive shape of a fork end – you may be using forks on your forklifts that are too long.
Pallets are usually sized following a specific standard. For your employees to safely move the loaded pallets with their forklifts to their nominated destination, the forks should be long enough to ensure full support and stabilization of the load.
If the ends of the forks protrude past the outside edge of the pallet, they can cause a problematic and even dangerous situation. Protruding forks are like an accident waiting to happen. The same goes for forks that are too short.
Extendable forklift fork attachments
Manually extendable forks stay on the forklift truck permanently, saving space, money, and time compared to traditional fork extensions (outer sleeves). This mechanical option is lower in cost than the hydraulic fork which makes it ideal for low-usage applications.
The Manual ReachForks are ideal for this application. A fingertip release lever unlocks the outer fork allowing the operator to easily position it in the extended or retracted position. The way to adjust the outer sleeve is highly innovative. It simply involves moving a pin (which also serves as a grease nipple). As soon as the locker is disengaged, the outer sleeve can be moved using the other hand until the locker engages again at a different length. Ideal for different pallet sizes and dual pallet handling.
Cross Docking Hydraulic ReachForks MHS
Hydraulic extendable forks
Forklift operators now have the convenience of being able to adjust the length of their forks from within the cab. This is done by manually operating a lever and does not require the operator to exit the forklift. Hydraulic extendable forklift forks allow drivers to customize their forks according to the task at hand.
The Hydraulic ReachForks can be used for double-deep pallet stacking, loading and unloading trucks and trains, for dual pallet load transport, and as extensions for the handling of pallets when a variety of different pallet sizes are used. Depending on the application we can include one or two cylinders in each fork.
The sliding fork attachments are fitted with an integrated synchronization system allowing the ReachForks to be extended and retracted in unison. It is even possible to fit these telescopic forks with cameras to have better visibility during double-deep pallet stacking. A "length measuring system" can be installed if more pallet sizes are used. Via a dedicated app, the operator can specify different length sizes. The ReachForks stop at the pre-programmed length so that the length of the forks matches the size of the lifted pallet.
Having the proper-sized forks on your lift trucks will make your business safer, more efficient, and more profitable.
For more information, please contact us!
Meijer Handling Solutions:
Visit website
Send a message
Connect on LinkedIn
