XCMG's brand new Port Machinery Container Reach Stackers
- 1 Jun 2023 ( #1130 )
XCMG, China's No. 1 for construction machinery, introduces their range of Reach Stackers specifically developed for port requirements.
Fuel series container reach stacker
Introduction:
  1. Intelligent and efficient: controller, joystick, pump, valve, combined with dynamic power matching technology reduce the system response time from 0.7s to 0.3s, leading to sensitive reaction and efficient operation.
  2. Comfortable operation: full view driver's cab, aviation joystick, ergonomic seat, six-way adjustable steering gear and humanized control part layout, greatly reducing operational fatigue.
  3. Energy conservation and environmental protection: Flow self-adaptive load sensitive hydraulic system enables the displacement and pressure of pump to be accurately adjusted according to the load in real time, avoiding overflow loss and effectively reducing energy consumption.
  4. Safe and reliable: rear millimeter wave radar, detection distance 15m, when reversing, alarm will be issued when entering warning area, automatic brake will be actioned before the danger zone. Intelligent adjustment of damping oil cylinder can solve the problems of slow leveling of empty tank and large swing of heavy tank.
Multiple selection of spreaders:
Standard spreader, empty container spreader, tilting spreader, front flip spreader, log clutch spreader, wind power tower drum spreader, wind power hub spreader, universal hook.
High-end core components:
Full range core components are industry-leading brands: Cummins, Volvo and Scania engines, Dana and XCMG transmissions, Kessler and Meritor drive axles, Parker and Hengli oil pumps, Parker, Linde and Hengli valves, IFM and Wika controllers, P&G and Danfoss handles, COBO steering rack, Grammar seat.
Featured product — XCS70S Large tonnage reach stacker:
XCS70S reach stacker is applicable for hoisting and short-distance transfer of wind power tower drum and hub. With large load and small wheelbase, the 70t reach stacker has the minimum wheelbase, which is flexible and suitable for lifting in the plant area; Kessler D111 series drive axle is adopted to make driving with load safer.
Featured product — XCS150S Large tonnage reach stacker:
XCS150S reach stacker is applicable for lifting of large bulk goods, such as petrochemical and offshore wind power industries. Telescopic frame structure, high stability of heavy load, wheel-side drive (hydraulic motor+reducer) type, high and low gear switching, and strong gradeability of heavy load.
Electric series container reach staker
Introduction:
XCS4531E electric container reach stacker adopts the industry's first "motor direct drive" technical solution, which means that the entire vehicle has no transmission. Utilizing XCMG's core independent power intelligent matching and optimization technology, integrated intelligent control is implemented for the power, rotation speed, torque, etc. of the entire vehicle's motor, combining intelligent thermal management system, energy recovery, three-level fault safety protection, and other functional designs to achieve intelligent, efficient, and safe operation of the vehicle. It meets the environmental usage requirements of -40°C to 50°C and is widely used in ports, docks, railways, freight yards, and other conditions.
Main features of electric reach stacker:
Good:
  • Good to the environment: Zero emission, green and energy-saving, quiet and low noise operation of the entire machine.
  • Good performance: Motor direct drive power system, high efficiency.
  • Good linkage: Lifting and telescoping are independently supplied with oil, and the linkage does not affect each other.
  • Good safety: The battery pack is arranged on both sides of the vehicle, providing convenient maintenance and good safety.
  • Good reliability: The lifting oil pump and recovery motor are arranged independently, with high service life and reliability.
Fast:
  • Fast Response: Fuel free power products lift multi-way valve, pump through the oil cylinder, action without delay, fast response.
  • Accelerate Fast: High power drive motor, quick start acceleration.
  • Fast operation: Two groups of large displacement oil pumps supply oil, lifting speed increased by 33% (reach stacker).
  • Charging fast: 300kW charging pile double gun fast charging, 85min (reach stacker) /75min (container handler) full.
XCMG is also looking for material handling partners all over the world. For more information, please contact us!
Contact us! | Whatsapp: +86 15852243987
Tel: 86-0516-87739198 | Web: www.xcmg.com
