XCMG Port Machinery Counterbalanced Forklifts
- 27 Apr 2023 ( #1125 )
Fuel series counterbalanced forklift:
Introduction:
  1. Intelligent and efficient: industry-leading electronic control technology that can achieve precise control of loads and improve work efficiency. The electronic micro movement function ensures more accurate stacking operation of goods.
  2. Comfortable operation: fully enclosed driver's cab, shock-absorbing suspended seats, intelligent temperature regulation high-power air conditioning, single handle control mode, greatly reducing operational fatigue.
  3. Energy conservation and environmental protection: Automatically detect vehicle operating conditions, identify dynamic power requirements, actively adjust and control engine speed, ensure that the engine operates in the optimal operating area, and reduce system fuel consumption by 10%.
  4. Safe and reliable: The structural design is sturdy and durable, suitable for loading and unloading heavy loads; The combination of precise weight matching technology and electronic control active protection technology ensures the high stability of forklifts.
  5. Excellent heat dissipation performance: With a larger radiator design and shock absorption protection for the radiator, the scientific layout of the heat dissipation system ensures high intensity operation in a 45°C environment, and the water temperature is maintained at around 98°C.
Technical highlights:
  • Multiple selection of mast and attachments:
    • Duplex mast, Duplex free lifting mast, Triplex free lifting mast, Fork positioner, Sideshift fork, Pole, Rotary fork, Holding clamp, Drum clap, Container spreader, tyre clamp, hook.
  • Rapid changing of fork - simple, convenient
    • It has the function of fork positioner and side shift to improve the operation efficiency.
    • Modular design concept, the side shift fork positioner adopts the bracket hook attachment quick-change system to realize the rapid replacement between different attachments, and the operation is efficient.
  • Active safety control technology:
    • Up to 13 active safety control technologies enjoy car-level safety assurance.
  1. Buffer at the top and bottom of the mast
  2. Tyre pressure monitor system
  3. Auto fire extinguish system
  4. Speed control
  5. MSD service switch, one-button power off
  6. Blue/red alarm light
  7. 360° surround view system
  8. Seat OPS system
  9. HV interlock, insulation monitoring, insulation detection
  10. Rear view camera
  11. Reverse automatic braking system
  12. Parking sensor
  13. Steering speed limiter
Electric series counterbalanced forklift:
Introduction:
The electric counterbalanced electric forklift is independently developed based on the high-voltage electric flow machine products of XCMG Port Machinery. It has multiple key technologies such as high-voltage lithium battery applications, permanent magnet synchronous motor control, intelligent thermal management, energy recovery, and active safety control of forklifts.
  1. Safety: protection level: IP67, binding level: H, vehicle stability coefficient: 1.5.
  2. Efficient: Motor direct drive technology, with a motor efficiency of 92%.
  3. Energy saving: Energy recovery technology+load sensitive hydraulic system application.
  4. Environmental protection: low noise, zero emissions.
  5. Comfortable: PTC electric auxiliary heating, faster heating, thumb handle, more flexible operation.
  4. Speed control
  8. Seat OPS system
  12. Parking sensor
XCMG is also looking for material handling partners all over the world. For more information, please contact us!
Contact us! | Whatsapp: +86 15852243987
Tel: 86-0516-87739198 | Web: www.xcmg.com
