VETTER Forks at ProMat 2023
- 23 Mar 2023 ( #1120 )
Discover probably the world's largest product portfolio of forks!
At first glance, the fork is not a spectacular product. Inconspicuous, but tirelessly in use everywhere and indispensable. But how sophisticated, innovative, versatile and exciting such a product is really often only becomes apparent when you take a look behind the scenes.
SmartFork® sensor fork – a new era in material handling
The SmartFork developed by VETTER is a real trendsetter. To name but a few solutions: The SmartFork FrontCam and the SmartFork SideCam are two integrated camera solutions that significantly improve the driver's view in front of and onto the load. Automatic switching of the two systems ensures safe transport in all situations. With this system the driver can see everything that is happening in front of his lift truck via the same monitor, even though the load is picked up. People and obstacles are detected at an early stage and damage is reduced.
Another clever solution is the SmartFork Laser as an aiming aid, picking up loads in the rack storage area gets easier and safer. The line laser installed in the fork tip draws a horizontal line on the load carrier so that the forklift operator can clearly see that he is entering the pallet at the correct height.
Especially designed for AGVs there is a wide variety of additional integrated sensors available. This makes SmartFork a real enabler to make AGVs fit for sophisticated solutions.
CROC fork coatings: Better and safer work with the best grip
With the innovative CROC ForkCoating, the goods to be transported no longer slip off the forks during braking, making it possible to transport sensitive goods in particular safely.  A pleasant side effect: the damping effect of the CROC coatings reduces the noise level. The colored coating also means significantly improved visibility of the forks, making tripping hazards in the workplace a thing of the past. Another benefit: CROC ForkCoatings are gentle on the surfaces of sensitive goods and prevent scratches!
VETTER – it’s all about forks
Today, VETTER is Europe's leading manufacturer of forks with increasing presence in the US. At its production sites in Germany and the USA, the company manufactures what is probably the most extensive range of forks for well-known manufacturers and service partners in the material handling industry. From standard forks, BigForks, FTP forks or lumber forks to special designs or intelligent solutions for Logistics 4.0 - always the right fork for almost any application. All under the motto "the world's best forks for the world's best industrial trucks".
Convince yourself!
Above all the VETTER team is looking forward to the exchange with many nice people from all parts of the world! Therefore:
Visit VETTER at the exhibition booth N6329 at ProMat 2023 and see for yourself the latest technology for modern and safe warehouse logistics.
VETTER Forks, Inc.
1711 Opportunity Avenue
Chambersburg, PA 17201, USA
Web: www.forks.com
Tel: +1 717 753 3913
Fax: +1 717 753 3915
Contact: get in contact
Get in touch with VETTER Forks, Inc.
VETTER Forks, Inc.
+1 717... Show
VETTER Forks, Inc.
VETTER Forks, Inc.
