The BRAVA multifunction armrest: flexible and tough
- 2 Jun 2022 ( #1079 )
Ideal for wide-ranging applications in harsh environments: The BRAVA multifunction armrest guarantees a high level of flexibility when equipping industrial trucks, agricultural and construction machinery as well as in numerous industrial applications.
It comprises an arm support and a control unit, which can be selected and configured to suit the application.
The armrest can be equipped with three different control untis, the ACTRA MONO 300, ACTRA MONO 400 and the ACTRA JOY.
The newly developed control unit ACTRA JOY ensures a maximum of variability: It can be equipped with two joystick, a travel direction switch and with up to three auxiliary buttons.
The ACTRA MONO 300 and ACTRA MONO 400 can be equipped with a maximum of four single-axis joysticks. The 300 model has three standard thumb controls, while the 400 has two standard thumb controls plus a thumb joystick.
The high degree of functionality, excellent ergonomics and sensitive control ensure fatigue-free and precise work.
The control units allow all of a vehicle's functions to be controlled with the right hand. They are shaped to allow the hand to rest comfortably. Due to sensitive control and ergonomic layout, all controls can be operated with a natural finger movement.
The use of non-contacting Hall-effect sensors guarantees a long service life. The controls remain extremely reliable, even under extreme loading conditions. Due to their encapsulated electronics and laser-etched symbols, the controls are ideal for use in harsh environments.
Armrest
The shape of the armrest was designed to correspond to the natural, and thus comfortable, angle of the operator' arm. The padded contact surface is made of hard-wearing material and is easy to clean. The armrest can be adjusted horizontally. Pulling the clearly visible handle on the armrest up with the right hand allows the armrest to be set to six different positions and thus optimally adjusted to suit the operator. A panel is situated in front of to the arm support. If required by the customer, this can be machined and equipped with additional control elements.
Height adjustment unit
The height adjustment unit is bolted to the vehicle's seat. A pushbutton allows the height adjustment to be unlocked and steplessly adjusted to the desired height.  The integrated gas strut enables the armrest to be adjusted with a minimum of effort.
For more information, please contact us!
Gebrueder Frei
Sonja Stahl
Tel: 07432 202 200
Web: www.frei.de
Email: Send an email
Visit our: ShopFront
CeMAT Australia 2025 has been underway in Sydney this week, wrapping up today, with the main topics coming out of the event proving to be the very predictable automation and sustainability... Continue reading
